2003 Acura TL Window Regulator Replacement
  1. 2003 Acura TL Window Regulator Replacement, Window Regulator: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2003 Acura TL Window Regulator Replacement, Window Regulator: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2003 Acura TL Window Regulator Replacement, Window Regulator: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the screw covers and screws behind the door handle and on the center doorframe.
    • Set them aside for reassembly.
    • If you're working on reassembling specifically the front driver's side door, you may have to remove the handle by shifting it right, then detaching it by unplugging the memory board located on the back. Other passenger doors won't have this additional step.
  2. 2003 Acura TL Window Regulator Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2003 Acura TL Window Regulator Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2003 Acura TL Window Regulator Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a trim removal tool, begin separating the door cover from the door. While separating, carefully undo the clips attaching the door to its frame.
    • The clips are very fragile. Ensure the clips don't get damaged during separation.
  3. 2003 Acura TL Window Regulator Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully unplug the speaker and window control cable connectors from the door. Press down on each connector to release it from its socket.
    • The driver's side door, which has a memory board, may have additional wires to disconnect.
  4. 2003 Acura TL Window Regulator Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2003 Acura TL Window Regulator Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull off the weather seal so you have access to the internal part of the door.
    • Try to avoid tearing it as you will need to use it once you are done with the repair.
  5. 2003 Acura TL Window Regulator Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2003 Acura TL Window Regulator Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If your window motor is already broken, you may have trouble keeping your window pane from falling if you are working by yourself.
    • Place a solid wood stick or other material in the door cavity below the window to prop the pane up.
    • The stick is to ensure the pane is properly secured when removing the window pane, but it may not be necessary if you're working on this project with someone else. Additionally, if you don't have a stick or an extra set of hands, try using durable tape to secure the glass to the top of the frame.
  6. 2003 Acura TL Window Regulator Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2003 Acura TL Window Regulator Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2003 Acura TL Window Regulator Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a socket wrench to unscrew the bolts attaching the window regulator to the doorframe.
    • You may need to tear the weather seal back more to have better access to the bolts.
  7. 2003 Acura TL Window Regulator Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2003 Acura TL Window Regulator Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2003 Acura TL Window Regulator Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the bolts out from inside the doorframe.
    • Remove the window regulator.
    • Replace the old window regulator with the new one, rescrewing bolts and reassembling the doorframe.
Vince Vanzura
crwdns2935283:006/11/25crwdne2935283:0
145 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 40-23, Kilpatrick Summer 2025 crwdns2935289:0University of North Texas, Team 40-23, Kilpatrick Summer 2025crwdne2935289:0
UNT-KILPATRICK-SU25S40G23
crwdns2942667:0crwdne2942667:0 82
