2003-2007 Honda Accord Oil and Oil Filter Change
  1. 2003-2007 Honda Accord Oil and Oil Filter Change, Opening the Hood: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2003-2007 Honda Accord Oil and Oil Filter Change, Opening the Hood: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the hood latch beside the driver's side door, next to the left foot rest.
    • Pull the latch toward you to release the hood.
  2. 2003-2007 Honda Accord Oil and Oil Filter Change: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2003-2007 Honda Accord Oil and Oil Filter Change: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Walk around to the front of the vehicle.
    • Slide your hand under the hood, directly above the Honda emblem. Locate and pull the hood tab to unlock the hood.
    • Once the tab is released, lift the hood up.
  3. 2003-2007 Honda Accord Oil and Oil Filter Change: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2003-2007 Honda Accord Oil and Oil Filter Change: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your left hand to hold the hood up. Locate the hood stand and pull it out of the clip.
    • Place the tip of the hood stand into the hole located in the upper left of the hood.
    • You can now let the hood rest on the stand.
  4. 2003-2007 Honda Accord Oil and Oil Filter Change, Using a Floor Jack: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2003-2007 Honda Accord Oil and Oil Filter Change, Using a Floor Jack: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the hydraulic floor jack under the vehicle until the saddle is directly under the crossmember.
    • The crossmember is the long metal support beam that runs underneath from the front fender to the rear fender on both sides of the car.
    • The saddle is the round metal part of the jack that moves upward as you pump the jack up.
  5. 2003-2007 Honda Accord Oil and Oil Filter Change, Using floor jack to lift car.: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push downward on the jack's lever to lift the saddle upward so that it contacts the crossmember. Continue pushing downward on the lever to lift the car upward.
  6. 2003-2007 Honda Accord Oil and Oil Filter Change: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the jack stand under the jack mounting point.
    • The jack mounting point is a metallic protrusion beneath each of the car doors.
  7. 2003-2007 Honda Accord Oil and Oil Filter Change: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Raise the jack stand until it contacts the jack mounting point.
    • In the event the floor jack fails, the jack stand is designed to prevent the car from falling.
  8. 2003-2007 Honda Accord Oil and Oil Filter Change, Engine oil and oil filter: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2003-2007 Honda Accord Oil and Oil Filter Change, Engine oil and oil filter: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the dipstick by lifting vertically.
    • Wipe all the oil off of the dipstick and put it back into the dipstick port.
  9. 2003-2007 Honda Accord Oil and Oil Filter Change: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the dipstick and examine the oil levels. The oil level should be between the two dots on the dipstick.
  10. 2003-2007 Honda Accord Oil and Oil Filter Change: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the oil fill cap on top of the engine and unscrew it.
  11. 2003-2007 Honda Accord Oil and Oil Filter Change: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2003-2007 Honda Accord Oil and Oil Filter Change: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After driving, engine oil needs time to cool before it can be safely changed. Wait about one hour after the engine has been turned off before attempting to change the oil.
    • Crawl under the front of the car on your backside and identify the oil drain plug.
    • If there is any oil or residue around the drain plug, be sure to wipe it off before continuing.
  12. 2003-2007 Honda Accord Oil and Oil Filter Change: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the oil drip pan under the drain plug and begin to loosen the drain plug with a 17mm wrench.
  13. 2003-2007 Honda Accord Oil and Oil Filter Change: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2003-2007 Honda Accord Oil and Oil Filter Change: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen drain plug slowly by hand until the bolt is completely removed and oil begins to flow, re-positioning the oil drip pan if needed.
  14. 2003-2007 Honda Accord Oil and Oil Filter Change: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Let the oil completely drain into the drip pan.
    • Put a new crush washer on the drain bolt, then reinstall the drain bolt.
    • Using a torque wrench, tighten it to:
    • 33 lbf·ft (45 N·m , 4.6 kgf·m) for 4-cylinder models
    • or 29 lbf·ft (39 N·m , 4.0 kgf·m) for 6-cylinder models.
    • Set the drip pan aside.
  15. 2003-2007 Honda Accord Oil and Oil Filter Change: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2003-2007 Honda Accord Oil and Oil Filter Change: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2003-2007 Honda Accord Oil and Oil Filter Change: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Identify the oil filter and place drip pan under the oil filter to catch falling oil.
    • Using a pair of channel locks, or flexible oil filter wrench (uses a strap to grip the filter), grip the oil filter tightly and twist counterclockwise to loosen.
    • Oil will drip out from the threads as you loosen it so have the oil drip pan ready.
  16. 2003-2007 Honda Accord Oil and Oil Filter Change: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2003-2007 Honda Accord Oil and Oil Filter Change: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2003-2007 Honda Accord Oil and Oil Filter Change: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slowly loosen the oil filter by hand until it is free.
  17. 2003-2007 Honda Accord Oil and Oil Filter Change: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2003-2007 Honda Accord Oil and Oil Filter Change: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Drain the remaining oil in the filter by inverting it over the drip pan.
    • Be sure to wipe down any oil that might have leaked during the process.
    • Check the old filter to ensure the gasket is in place. IF it is missing, it may be sticking to the engine block and should be removed prior to installing the new filter.
  18. 2003-2007 Honda Accord Oil and Oil Filter Change: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2003-2007 Honda Accord Oil and Oil Filter Change: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Get the replacement filter and lightly spread clean engine oil onto the rubber gasket of the new filter.
  19. 2003-2007 Honda Accord Oil and Oil Filter Change: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Thread the new filter into the oil filter port by turning the filter clockwise.
    • Once the rubber gasket contacts the engine block, hand-tighten the filter plus 1/4 turn.
    • Over tightening may cause the gasket to break and leak oil.
  20. 2003-2007 Honda Accord Oil and Oil Filter Change: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a funnel, pour 5 quarts of 5W-20 oil into the opening, making sure not to spill oil onto or around the engine.
    • Screw on and tighten the oil fill cap.
crwdns2935229:030crwdne2935229:0
Shaun MacDonald
crwdns2935283:010/03/12crwdne2935283:0
2 606 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 24-27, Regan Fall 2012 crwdns2935289:0Cal Poly, Team 24-27, Regan Fall 2012crwdne2935289:0
CPSU-REGAN-F12S24G27
crwdns2947412:025crwdne2947412:0
Excellent tips and advice my brotha thnk. U keep up the great work
Leonardo - crwdns2934203:0crwdne2934203:0
You should do it while the engine is hot so the oil drains faster. Removing the the fill cap should be done before removing the drain plug. That will also help the oil drain faster and more completely. And 5 quarts is too much for that engine. It's more like 4.4 or 4.5 quarts. Over filling it is really bad. The counterweights on the crankshaft will splash in the oil creating a froth with air bubbles in it causing the oil to not lubricate the engine well which will wear out the engine faster
radloffmatthew - crwdns2934203:0crwdne2934203:0
Yeah. What he said. Well maybe not a hot engine... But certainly not a cold one.
codeh d -
Can u pls help me for my accord problem
I just recently change my oil last 3 months and now the dipstick is showing no oil I had use castrol edge 5w-40 fully synthetic oil and now there is no oil can u pls help me
Siddhant Mhatre -
Don't change oil when really hot. You WILL burn yourself.
zamerijhoff -
crwdns2936751:024crwdne2936751:0 21
crwdns2936753:07crwdne2936753:0 182
crwdns2936753:030crwdne2936753:0 624
crwdns2942667:0crwdne2942667:0 338,289
