The purpose of this guide is to show how to replace the standard headlight bulb of a Honda Accord. This guide is specifically for Accords manufactured in-between 2003 and 2007. Newer or older models may be similar, but not exactly the same. Avoid touching the glass of the headlight bulb as oil and dirt on the glass can hamper its performance and lifespan.
Enter your vehicle from the driver's side, and locate the hood lever (in the footwell) near the far left side of the vehicle.
Pull the hood lever towards you in order to pop the hood of your vehicle.
Reach underneath the front middle of the hood to open the hood.
Press upwards on the lever on the underside of the hood in order to fully open the hood.
Once the hood is lifted, secure the hood by lifting up the hood prop.
Use the adjustable wrench to loosen the two hex nuts located on either side.
Once you have removed the mount, carefully lift the battery out of the vehicle.
Grab the plug and twist it counterclockwise to loosen it. It should pop out fairly easily.
To reassemble your device, follow these instructions, starting from step 12, until step 5, in reverse order.
