2003-2007 Honda Accord Headlight Bulb Replacement
  1. 2003-2007 Honda Accord Headlight Bulb Replacement, Headlight Bulb: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2003-2007 Honda Accord Headlight Bulb Replacement, Headlight Bulb: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Enter your vehicle from the driver's side, and locate the hood lever (in the footwell) near the far left side of the vehicle.
  2. 2003-2007 Honda Accord Headlight Bulb Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2003-2007 Honda Accord Headlight Bulb Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the hood lever towards you in order to pop the hood of your vehicle.
  3. 2003-2007 Honda Accord Headlight Bulb Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2003-2007 Honda Accord Headlight Bulb Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2003-2007 Honda Accord Headlight Bulb Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reach underneath the front middle of the hood to open the hood.
  4. 2003-2007 Honda Accord Headlight Bulb Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2003-2007 Honda Accord Headlight Bulb Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press upwards on the lever on the underside of the hood in order to fully open the hood.
  5. 2003-2007 Honda Accord Headlight Bulb Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2003-2007 Honda Accord Headlight Bulb Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2003-2007 Honda Accord Headlight Bulb Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the hood is lifted, secure the hood by lifting up the hood prop.
  6. 2003-2007 Honda Accord Headlight Bulb Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2003-2007 Honda Accord Headlight Bulb Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • I attempted to highlight the location of the plug for the bulb as best as possible, so you can at least know what area we are attempting to access.
    • The bright white object is the plug.
  7. 2003-2007 Honda Accord Headlight Bulb Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2003-2007 Honda Accord Headlight Bulb Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2003-2007 Honda Accord Headlight Bulb Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • In order to replace the bulb on the driver's side, we need to remove the battery.
    • Use the adjustable wrench to loosen the two hex nuts located on either side.
    • Don't fully unscrew the nuts holding the mount to the battery.
  8. 2003-2007 Honda Accord Headlight Bulb Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2003-2007 Honda Accord Headlight Bulb Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2003-2007 Honda Accord Headlight Bulb Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once you have removed the mount, carefully lift the battery out of the vehicle.
    • The car battery is much heavier than it looks and is very easy to underestimate. Proceed carefully.
  9. 2003-2007 Honda Accord Headlight Bulb Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2003-2007 Honda Accord Headlight Bulb Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2003-2007 Honda Accord Headlight Bulb Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the plug and twist it counterclockwise to loosen it. It should pop out fairly easily.
    • If it does not come out easily, do not force it. The plastic will break.
    • Attempt to spray the compressed air in the area of the plug. Sprayed in the crevice where it turns, this should allow it to move easier.
  10. 2003-2007 Honda Accord Headlight Bulb Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2003-2007 Honda Accord Headlight Bulb Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2003-2007 Honda Accord Headlight Bulb Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the bulb out from the vehicle.
    • Avoid touching the glass of the bulb as oil and dirt on the glass can hamper its performance and lifespan.
To reassemble your device, follow these instructions, starting from step 12, until step 5, in reverse order.
Brooklyn Jarvis
crwdns2935283:010/07/21crwdne2935283:0
262 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 11-42, Grodsky Fall 2021 crwdns2935289:0CSU Los Angeles, Team 11-42, Grodsky Fall 2021crwdne2935289:0
CSULA-GRODSKY-F21S11G42
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 47
crwdns2936753:030crwdne2936753:0 172
crwdns2942667:0crwdne2942667:0 3,465
