If your 2003-2008 Pontiac Vibe suffers from symptoms like shaking or vibrating, engine rattling, increased gas mileage, or increased exhaust emissions, there’s a chance you need to replace the air fuel sensor.
This guide will help you replace the air fuel sensor on your 2003-2008 Pontiac Vibe. You will need an air fuel sensor, a socket wrench, and an O2 sensor socket for this repair.
Important note: your car must be completely off to complete this repair!
Open the hood and locate the old air fuel sensor.
The air fuel sensor is located above the catalytic converter (upstream).
Disconnect one end of the old sensor by pressing the button. The circle in the first image shows the button.
Take the 5-point O2 sensor wrench and socket and put it on the other end (downstream) of the old air fuel sensor.
Turn the wrench counterclockwise until the old air fuel sensor detaches.
Pull out the old air fuel sensor.
Locate the new air fuel sensor.
Locate the tube of anti-seize lubricant that came with the new sensor.
Apply the oil lightly to the threads.
Insert the newly oiled air fuel sensor.
Tighten the sensor with the O2 sensor wrench.
Turn your ignition on.
Check your dashboard to see if the check engine light is still on.
If the light is still on, turn the car off and wait a few minutes. Then turn the car back on and check the light again.
If the check engine light is still on, then use a code reader to see what is wrong with the car.
crwdns2917034:0crwdne2917034:0
STEP 3 SAYS "Take the 5-point O2 sensor wrench and socket and put it on the other end (downstream) of the old air fuel sensor." DOWNSTREAM? I thought we were working on UPSTREAM. I'm goin fishing !!!
