2002-2006 Toyota Camry Passenger Side View Mirror Replacement
  1. 2002-2006 Toyota Camry Passenger Side View Mirror Replacement, Passenger Side Vew Mirror: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2002-2006 Toyota Camry Passenger Side View Mirror Replacement, Passenger Side Vew Mirror: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2002-2006 Toyota Camry Passenger Side View Mirror Replacement, Passenger Side Vew Mirror: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the trim paneling located at the base of the side view mirror.
    • It should detach rather easily with just the use of your hands. If not, place the tip of the flat head screwdriver into the gap and gently pry the paneling off.
  2. 2002-2006 Toyota Camry Passenger Side View Mirror Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2002-2006 Toyota Camry Passenger Side View Mirror Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2002-2006 Toyota Camry Passenger Side View Mirror Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Begin to disconnect the electrical connector located in the center of the three 10mm bolts.
    • You can find the lock pad by locating the release tab on the top of the electrical connector.
    • Use your flat head screwdriver to push in on the lock pad. Then, press in on the electrical connector
  3. 2002-2006 Toyota Camry Passenger Side View Mirror Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2002-2006 Toyota Camry Passenger Side View Mirror Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2002-2006 Toyota Camry Passenger Side View Mirror Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Detach the electrical connecter completely. Place your flathead screwdriver in the gap to gain leverage and pull on the connector.
    • Be careful not to pull on the wires.
  4. 2002-2006 Toyota Camry Passenger Side View Mirror Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2002-2006 Toyota Camry Passenger Side View Mirror Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2002-2006 Toyota Camry Passenger Side View Mirror Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three 10mm bolts using your 10mm socket and ratchet extension.
    • Ensure you are holding the mirror so it does not fall to the ground while removing the bolts.
  5. 2002-2006 Toyota Camry Passenger Side View Mirror Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2002-2006 Toyota Camry Passenger Side View Mirror Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the side view mirror.
    • Keep a firm grip so the side mirror is not dropped and no glass is shattered.
  6. 2002-2006 Toyota Camry Passenger Side View Mirror Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2002-2006 Toyota Camry Passenger Side View Mirror Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2002-2006 Toyota Camry Passenger Side View Mirror Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Mount the replacement side view mirror.
    • Make sure it is flush with the car.
    • Continue to hold the replacement side mirror in place until you have tightened the 10mm bolts enough to keep it mounted.
Alexandria Golden
crwdns2935283:010/29/19crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
University of Memphis, Team S1-G6, Willis Fall 2019 crwdns2935289:0University of Memphis, Team S1-G6, Willis Fall 2019crwdne2935289:0
UM-WILLIS-F19S1G6
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 5,215
