You should check your coolant level every few months. If your Dodge overheats, you will need to check the coolant level and replace coolant. Occasionally, you might need to completely drain and replace the coolant. Due to limited resources the coolant was not actually replaced in this guide.
Locate the coolant reservoir, near the front of the engine bay.
Locate the coolant reservoir cap and remove it by pressing down and turning it counterclockwise.
If the coolant level is low, fill up the reservoir using a 50/50 mixture of antifreeze and distilled water.
If you need to completely drain the coolant, place a bucket underneath the coolant hose, near the front of the engine.
Locate and loosen the hose clamp on the coolant hose with the flat head screwdriver. The coolant hose is located near the bottom of the serpentine belt underneath the front of the engine bay.
Drain the coolant completely and reattach the coolant hose, tightening the hose clamp with the flat head screwdriver.
To dispose of your used coolant, take it to an automotive parts store or to any landfill that accepts hazardous materials. Do not pour coolant down any drains or sinks. Serious ecological damage could occur.
crwdns2935229:05crwdne2935229:0
Thanks a million very helpful advice !
