2001-2005 Honda Civic Headlight Bulb Replacement
  1. 2001-2005 Honda Civic Headlight Bulb Replacement, Headlight Bulb: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2001-2005 Honda Civic Headlight Bulb Replacement, Headlight Bulb: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2001-2005 Honda Civic Headlight Bulb Replacement, Headlight Bulb: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unlock your hood by pulling on the hood release located by the front of the driver side door.
    • Find the release near the center of the hood and push up on it to pull up the hood.
    • Prop the hood up in place. The end of the prop is found near the battery and it lays across the front of the hood.
  2. 2001-2005 Honda Civic Headlight Bulb Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2001-2005 Honda Civic Headlight Bulb Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2001-2005 Honda Civic Headlight Bulb Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This step is only needed if you want to replace the headlight bulb on the driver's side
    • Pull up on the power steering fluid reservoir to take it out of the holder.
    • Set the reservoir to the side to make room near the headlight.
  3. 2001-2005 Honda Civic Headlight Bulb Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2001-2005 Honda Civic Headlight Bulb Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This step is only needed if you want to replace the headlight bulb on the passenger's side.
    • Using the 10mm wrench undo the battery tie down by turning the bolt clockwise.
    • Move the battery out of the way of the headlight.
  4. 2001-2005 Honda Civic Headlight Bulb Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2001-2005 Honda Civic Headlight Bulb Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Put on a pair of latex or nitrile gloves.
    • Take hold of the headlight plug located directly behind the headlight.
    • Turn the bulb a quarter turn counter-clockwise to unlock it.
    • Pull out the plug.
    • Be careful to not break the bulb when taking out the headlight.
  5. 2001-2005 Honda Civic Headlight Bulb Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2001-2005 Honda Civic Headlight Bulb Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2001-2005 Honda Civic Headlight Bulb Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Find the release on the lower part of the headlight plug.
    • Push down on the release while pulling on the base of the headlight to remove the headlight bulb.
  6. 2001-2005 Honda Civic Headlight Bulb Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take the new headlight and plug it into the headlight plug
    • It is important that we wear the gloves and be careful with handling headlights as oils from human skin can easily damage them.
  7. 2001-2005 Honda Civic Headlight Bulb Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reinsert the plug with the new headlight on it.
    • Turn the plug a quarter turn clockwise to lock it in.
    • Gently tug the plug to make sure it is locked in place. If it isn't, redo this step.
  8. 2001-2005 Honda Civic Headlight Bulb Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2001-2005 Honda Civic Headlight Bulb Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you replaced the driver side headlight, plug the power steering fluid reservoir back in its place.
    • If you replaced the passenger side headlight, put the battery tie down back on by inserting the bolt and turning it counter-clockwise.
Shank
crwdns2935283:003/23/20crwdne2935283:0
268 crwdns2915208:0crwdne2915208:0
Purdue University Northwest, Team S10-G10, Hingst Spring 2020 crwdns2935289:0Purdue University Northwest, Team S10-G10, Hingst Spring 2020crwdne2935289:0
PNW-HINGST-S20S10G10
crwdns2936753:07crwdne2936753:0 39
crwdns2936753:030crwdne2936753:0 188
crwdns2942667:0crwdne2942667:0 18,608
