2001–2005 Honda Civic Side-View Mirror Replacement
  1. 2001–2005 Honda Civic Side-View Mirror Replacement, Side-View Mirror: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2001–2005 Honda Civic Side-View Mirror Replacement, Side-View Mirror: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure window is down and car is off before you begin.
    • Insert a plastic pry tool into the space between the mirror cover and mirror mount.
    • Pry around the edges to loosen it and remove the mirror cover.
    • The mirror cover must be removed to remove the door panel.
  2. 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove both screws from the door handle.
    • 4x12 mm oem tap screw
    • 5x20 mm oem tap screw
  3. 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the door handle to reveal the clip attached to the actuator rod.
    • Don't pull it off as it is connected to the power cable.
    • Apply slight pressure with your finger, or use needle-nose pliers to remove the clip from the actuator rod.
    • Rotating the clip to the right, away from the rod should disconnect the latch rod from the clip.
    • Do not apply excessive force as these clips have a reputation of becoming weak over time and can break.
    • Hold down the tabs and disconnect the power cable connector from the door handle.
    • Remove the door handle and set it aside.
  4. 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic opening tool to remove the screw cover in the armrest. Use a Phillips #2 screwdriver to remove the 4x16 self tapping screw.
    • Insert the pry tool into the armrest and apply slight pressure to remove the armrest.
  5. 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Squeeze the tabs and disconnect the power cable connector from the armrest.
    • Don't force the cable and don't pull the cable out by the wires or it may get damaged.
  6. 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Phillips #2 screwdriver to remove the 5x20 mm oem tap screws where the armrest was.
  7. 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the pry tool or a flat-blade screwdriver into the door panel and apply slight pressure to pop the door panel loose.
    • Lift and remove the door panel.
  8. 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Squeeze the connector tabs and disconnect the power cable from the mirror.
  9. 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Move the lever on the ratchet to the right to set it to loosen.
    • Use the 1/4 inch ratchet with an 8mm socket to remove the nuts by repeatedly rotating counterclockwise.
    • Although it’s common to associate left with loosening and right with tightening, keep in mind that when the ratchet is upside down, the lever may appear to point left—but the standard rules still apply.
    • Other ratchets may differ and be reversed (left to loosen, right to tighten).
  10. 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press the connector tab and with your other hand pull the mirror out to remove it.
    • If working with another person, have them pull the mirror on the other side of the door.
  11. 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Align the new mirror's mounting bolts with the holes.
    • Tighten the nuts with your hand first and then use the 1/4-inch ratchet to secure them.
  12. 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Put the door panel back on and make sure the door clips of the door panel align with the car.
    • Apply firm pressure and tap where the door clips are to ensure the door stays on.
    • Make sure the connectors are sticking out so you can reconnect your door handle and door panel.
  13. 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #2 screwdriver to replace the 5X20 mm OEM tap screws in the armrest cavity to ensure the door panel stays put.
  14. 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reattach the mirror cover and apply firm pressure to ensure that is stays on.
  15. 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reconnect the door handle.
  16. 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reattach the door clip by rotating it to the left onto the actuator rod.
    • Once the clip is reattached, you can insert the door handle back into place.
  17. 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the screwdriver to replace the door handle screws.
  18. 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Attach the armrest and make sure the cable connector goes under the door panel.
  19. 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 2001–2005 Honda Civic Side-View Mirror Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the screwdriver to secure the 4x16 mm self tapping screw to the armrest.
    • You have completed this guide!
Richard Gonzalez
crwdns2935283:003/04/25crwdne2935283:0
313 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 3-14, Grodsky Spring 2025 crwdns2935289:0CSU Los Angeles, Team 3-14, Grodsky Spring 2025crwdne2935289:0
CSULA-GRODSKY-S25S3G14
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 219
