1999 - 2003 Acura TL Ignition Coil Replacement
  1. 1999 - 2003 Acura TL Ignition Coil Replacement, Ignition Coil: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 1999 - 2003 Acura TL Ignition Coil Replacement, Ignition Coil: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the driver side door of car.
  2. 1999 - 2003 Acura TL Ignition Coil Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 1999 - 2003 Acura TL Ignition Coil Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the hood latch below the steering wheel and near the door frame towards you to pop open the hood.
  3. 1999 - 2003 Acura TL Ignition Coil Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 1999 - 2003 Acura TL Ignition Coil Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the hood slightly to where your fingers can fit under the hood.
    • Reach your fingers under the hood to find the latch that is slightly right off the center.
    • Pull and hold the latch up while simultaneously lifting the hood all the way up until it stays stationary.
    • Be careful that the hood is lifted properly to avoid an accident.
  4. 1999 - 2003 Acura TL Ignition Coil Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1999 - 2003 Acura TL Ignition Coil Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1999 - 2003 Acura TL Ignition Coil Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a flathead screwdriver to remove one screw from each corner of the cover.
  5. 1999 - 2003 Acura TL Ignition Coil Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the engine cover towards you to remove it.
  6. 1999 - 2003 Acura TL Ignition Coil Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1999 - 2003 Acura TL Ignition Coil Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1999 - 2003 Acura TL Ignition Coil Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pinch the socket, attached to engine coil, and pull up to release.
    • With an Allen key, loosen the screw holding the coil by turning counterclockwise.
    • Make sure to avoid exposed wires.
  7. 1999 - 2003 Acura TL Ignition Coil Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1999 - 2003 Acura TL Ignition Coil Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1999 - 2003 Acura TL Ignition Coil Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull out the old coil.
    • Avoid exposed wires.
  8. 1999 - 2003 Acura TL Ignition Coil Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1999 - 2003 Acura TL Ignition Coil Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1999 - 2003 Acura TL Ignition Coil Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the new coil.
  9. 1999 - 2003 Acura TL Ignition Coil Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 1999 - 2003 Acura TL Ignition Coil Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Attach the wire socket to the new coil until you hear a "click," indicating that it is properly inserted.
  10. 1999 - 2003 Acura TL Ignition Coil Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With an Allen key, tighten the screw into the new coil turning clockwise to secure into place.
  11. 1999 - 2003 Acura TL Ignition Coil Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1999 - 2003 Acura TL Ignition Coil Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1999 - 2003 Acura TL Ignition Coil Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reattach the engine cover and secure the screws with the flathead screwdriver.
Lhea Kathlyn Mae Domondon
crwdns2935283:008/29/23crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
California State University Bakersfield, Team 4-8, Chiang Fall 2023 crwdns2935289:0California State University Bakersfield, Team 4-8, Chiang Fall 2023crwdne2935289:0
CSUB-CHIANG-F23S4G8
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 462
