crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
Use a #2 Phillips screwdriver to remove the four screws.
Remove the rubber gasket from the rain tray.
Lift the tray upwards and away from the vehicle.
Use a flathead screwdriver to remove the cap from the windshield wiper.
Use a socket wrench to release the passenger-side windshield wiper locking nut.
Gently lift up the passenger-side windshield wiper.
Remove the driver-side windshield wiper in the same fashion.
Use an offset Phillips screwdriver to remove a screw in the back of the automatic control unit cover.
Use a #2 Phillips screwdriver to remove the front two screws.
Gently unplug and lift out the automatic transmission control unit.
crwdns2935229:09crwdne2935229:0
crwdns2947412:05crwdne2947412:0
Does the new TCU need to be programmed in any way?? Or is it just plug and play.
does it need to be programmed mine needs replacement my gears are not shifting
got a question if your display light is dim what could be the problem
Volkswagen tiguan won't start after disconnection, wat can I do to restart it
thank you very much .
