1998-2001 Nissan Altima Battery Replacement
  1. 1998-2001 Nissan Altima Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the hood of the car by pulling the lever until you hear the hood pop open.
    • Wear protective gloves when dealing with a car battery to protect against potential battery acid.
  2. 1998-2001 Nissan Altima Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the hood now open, identify the battery and the part number.
    • When replacing the battery, make sure that the new battery and old battery have the same part number to avoid issues.
  3. 1998-2001 Nissan Altima Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1998-2001 Nissan Altima Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1998-2001 Nissan Altima Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a torque wrench with a 9 mm attachment to unscrew the negative clamp and remove it from the terminal. Do the same with the positive terminal.
    • Make sure that no metal pieces touch the terminals at the same time, and that the clamps don't touch each other.
  4. 1998-2001 Nissan Altima Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1998-2001 Nissan Altima Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1998-2001 Nissan Altima Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If the terminals are corroded, take the corrosion brush and insert the terminal into it and turn until the corrosion is gone.
    • If there is no corrosion, go to the next step.
  5. 1998-2001 Nissan Altima Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1998-2001 Nissan Altima Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1998-2001 Nissan Altima Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery from the base.
    • Be careful as the battery is heavy. To prevent leakage of battery acid, never turn it upside down.
    • Wipe down the base and clamps with a damp rag to remove any dirt or dust that might be present.
  6. 1998-2001 Nissan Altima Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1998-2001 Nissan Altima Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1998-2001 Nissan Altima Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Dry the base and clamps fully with a dry rag.
    • The clamps must be fully dry.
    • Place the new battery into the base, making sure that the bracket on the bottom is in place.
  7. 1998-2001 Nissan Altima Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1998-2001 Nissan Altima Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1998-2001 Nissan Altima Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To prevent corrosion, you can place dielectric grease or petroleum jelly on the terminal before placing the clamps, but it isn't necessary.
    • Place the clamps onto the terminal.
    • Screw the negative clamp on first.
    • Don't screw it on too tight.
    • Repeat this step with the positive clamp.
  8. 1998-2001 Nissan Altima Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all tools from the battery.
    • Make sure to keep track of the time your battery has been in your car. They should be replaced every 3-4 years.
    • Do not throw away old batteries. They can be taken to most automotive shops to be discarded safely and appropriately.
Loreye
crwdns2935283:010/25/22crwdne2935283:0
205 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 2-9, Briggs Fall 2022 crwdns2935289:0CSU Los Angeles, Team 2-9, Briggs Fall 2022crwdne2935289:0
CSULA-BRIGGS-F22S2G9
crwdns2942667:0crwdne2942667:0 575
