This guide will show you how to replace the battery in a 1998-2001 Nissan Altima.
If turning the key in the ignition doesn't turn your car on, or the battery light turns on in the dashboard, it may be time to change out your car battery. Typical car batteries can have a 3-4 year lifespan but will vary from driver to driver; when batteries with corrosion aren't cleaned it can lead to serious damage to the clamps/terminals and a dead battery renders the car unusable.
Before using this guide, make sure to run through any other possible reasons for the car not turning on with the use of an OBD reader (car diagnostic scanner).
When following this guide, it's crucial to ensure that the engine is completely shut off to avoid injuries; additionally, make sure to never leave the wrench on the car battery. When not in use, place it to the side or in your pocket. If changing the battery doesn't allow your car to start it's recommended to run an OBD reader to identify further issues or take it to a mechanic for professional help.
Remove the key from the ignition, make sure the engine is off, and engage the parking brake before beginning this repair.
            Open the hood of the car by pulling the lever until you hear the hood pop open.
            With the hood now open, identify the battery and the part number.
            Use a torque wrench with a 9 mm attachment to unscrew the negative clamp and remove it from the terminal. Do the same with the positive terminal.
            If the terminals are corroded, take the corrosion brush and insert the terminal into it and turn until the corrosion is gone.
            Remove the battery from the base.
            Wipe down the base and clamps with a damp rag to remove any dirt or dust that might be present.
            Dry the base and clamps fully with a dry rag.
            Place the new battery into the base, making sure that the bracket on the bottom is in place.
            Place the clamps onto the terminal.
            Screw the negative clamp on first.
            Repeat this step with the positive clamp.
