As a car ages some of the connections can deteriorate. If your LCD display is not working properly with only some of the segments showing, or if the segments sometimes show and sometimes does not show, then it’s likely the result of a faulty connection. In some cases, the repair is relatively easy. Sometimes, the connection between the LCD and the circuit boards simply needs to be cleaned. In this case though, there is no connection that can be cleaned so the connection needs to be re-soldered. If you need more information on soldering check out the guide on iFixit.
Use the spudger to remove both side covers to access the radio removal holes.
Use the spudger to remove this plastic cover to make the radio removal easier.
Remove each side of the radio separately. Starting with the left side, put the 'radio removal tool' in the bottom 4 holes until you hear a "click"
Then pull the left side of the radio out.
Then repeat the process with the right side.
Pull the radio out, you may have to wiggle it back-and-forth several times to get it out.
Remove the radio Antenna.
Remove the wiring harness by pressing on the clip on the underside of the harness.
Using the Phillips #2 screwdriver, remove the two 5.0 mm screws on either side of the control panel.
Pry-off the control panel tabs with the spudger.
Using the spudger, pry the top control panel tabs off.
Using the spudger, pry the bottom control panel tabs off.
Re-solder the LCD connections with a soldering iron.
Re-clip the control panel back onto the radio.
Using a Phillips #2 screwdriver, screw in both 5 mm screws on either side of the radio.
Insert the radio back into it's place in the same way that you removed it.
crwdns2935103:0crwdne2935103:0
Great guide! When I was taking mine out to swap in an aftermarket, I by accidently didn't disconnect the battery and when attempting to remove deck with the 4 C clips, I guess I shorted the backlit LED in the original. The wires of my new (old aftermarket deck) just keep messing around so I want to put this original stock one back. I was wondering if you knew or could help me find out which piece of the board or LED to replace? The LCD itself works, just not the red LED backlight when the car lights are on.
IS there any way you can help me identify this piece that I might have shorted out by pulling your deck again? I'm guessing the LED's are on the opposite side of the picture 12.
Only if you are willing. I would really appreciate any help.
Thank you
-David
كيفية اصلاح الانارة الامامية . وهل يوجد توماتيك للانارة الامامية ام لا ؟
كيفية اصلاح الانارة الامامية. وهل يوجد تومتيك للانارة الامامية؟
