Air filters are used to clean and purify the air that goes into your engine. Overtime, they can become filthy and/or clogged. Changing out a nasty filter for a fresh clean one, can result in better performance. Mainly in acceleration. Here is a very good video to reference!
The air filter is located on the right side of the engine. Inside of the medium sized box (Outlined in photo with red box).
This is where we will be working primarily
Before doing anything, we must remove the sensor attached to the intake tube. The sensor is circled in the photo.
Pull up on the grey tab and pull the sensor up gently to release the sensor.
Using the flat-head screwdriver, unscrew the brace until it is very loose. but not completely off!
Simply tug on the rim of the tube and pull downward.
There, your intake tube is now off. Set this somewhere you will not lose it.
Undue the two tabs on the left and right sides of the filter box and lift the cover out.
Use the indent under the tab to pull the filter out.
The filter must go in the same direction as shown in the first photo.
The second photo shows the view of it from the inside of the engine bay.
When putting the filter box cover back on, be sure to line up the tabs and holes at the bottom of the box. Then securely snap the tabs back onto the filter box.
Push the engine side of the intake tube on first. Be sure to firmly press it back into place. You do not want the intake tube coming off while driving down the road.
For the filter-box half of the intake tube, first be sure to place the little tab on the tube inside of the notch as shown in the second photo.
Now tighten up that screw. Get it very tight. As with the other end of the intake tube, you do not want it coming off while driving.
Line up the plastic tab and push it into place. You should hear a small click.
Give both ends of the intake tube a tug to be sure they're tightly in place.
Now, close the hood and take it for a test drive.
Congratulations! Your air filter has been successfully installed. Now go enjoy your Grand Prix's improved performance!
Your air filter has now been replaced. Your acceleration should be improved! Enjoy!
crwdns2935229:05crwdne2935229:0
