Replacing burnt out or broken bulbs is a quick and easy fix that makes your car easier to see from behind, helping to prevent accidents.
Locate the plastic casing that holds the trunk liner in place, directly behind the tail light.
Unscrew the plastic casings.
Unscrew the three plastic wing nuts located behind the tail lights.
Carefully pull the tail light away from the car to expose the connected wires.
Unclip the rear panel of the tail light assembly. There are two clips on the top and two on the bottom.
Remove the rear panel from the rest of the assembly.
Grab the plastic base of the bulb and gently wiggle it free.
Gently push the new bulb into the plastic housing.
After putting the new bulbs in, turn the desired lights on to check that the newly installed bulbs work correctly.
