1996 Honda CBR900RR FireBlade Wheel Bearing Replacement
  1. 1996 Honda CBR900RR FireBlade Wheel Bearing Replacement, Wheel Bearing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1996 Honda CBR900RR FireBlade Wheel Bearing Replacement, Wheel Bearing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1996 Honda CBR900RR FireBlade Wheel Bearing Replacement, Wheel Bearing: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • On the left side of the motorcycle, use the 12 mm wrench to remove the bolts in the order indicated.
    • On the right side, use the 12 mm wrench to remove the first two bolts, the 22 mm wrench for the third, and finish up with the 12 mm on the remaining two.
  2. 1996 Honda CBR900RR FireBlade Wheel Bearing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 1996 Honda CBR900RR FireBlade Wheel Bearing Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the brake calipers away from the rotors.
    • Carefully use a metal spudger to slightly open the space between the pads.
  3. 1996 Honda CBR900RR FireBlade Wheel Bearing Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When the axle bolt has been removed, use the long 3/8" ratchet extension and deadblow hammer to drive the axle out.
    • The wheel will be loose, and can be removed from the motorcycle.
  4. 1996 Honda CBR900RR FireBlade Wheel Bearing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry the seal from the bearing race.
    • Flip the wheel over and repeat on the other seal.
  5. 1996 Honda CBR900RR FireBlade Wheel Bearing Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 1996 Honda CBR900RR FireBlade Wheel Bearing Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the long 3/8" extension, and inserting it at an angle as shown, you should be able to move the bearing spacer to the side and catch the inside of the bearing.
    • Once the extension is firmly planted on the bearing, use the hammer to tap the bearing downward, out of the race.
    • The bearing spacer will fall out.
    • Flip the wheel over and drive the other bearing out with the extension.
  6. 1996 Honda CBR900RR FireBlade Wheel Bearing Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Clean both bearing races with a clean towel and apply a very thin coat of grease.
  7. 1996 Honda CBR900RR FireBlade Wheel Bearing Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the bearing into the race and gently tap it with the hammer until it is even with the bearing race.
    • Place the 32mm socket onto the edge of the bearing.
    • Gently tap the bearing into the race until it stops.
  8. 1996 Honda CBR900RR FireBlade Wheel Bearing Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the wheel over and insert the bearing spacer.
    • Follow the above steps for installing the second bearing.
  9. 1996 Honda CBR900RR FireBlade Wheel Bearing Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 1996 Honda CBR900RR FireBlade Wheel Bearing Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently tap the bearing seal into the race until it is fully seated
    • Flip the wheel over and drive the second seal in.
    • All done! Repeat the removal steps to re-install the wheel.
Aaron Whitaker
crwdns2935283:010/11/22crwdne2935283:0
223 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 1-17, Friess Fall 2022 crwdns2935289:0University of North Texas, Team 1-17, Friess Fall 2022crwdne2935289:0
UNT-FRIESS-F22S1G17
crwdns2936753:030crwdne2936753:0 107
crwdns2942667:0crwdne2942667:0 2,773
