1996-2000 Honda Civic Headlight Bulb Replacement
  1. 1996-2000 Honda Civic Headlight Bulb Replacement, Preparation: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1996-2000 Honda Civic Headlight Bulb Replacement, Preparation: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1996-2000 Honda Civic Headlight Bulb Replacement, Preparation: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pop the hood via hood release latch by driver's side.
    • Reach for the latch under the hood and prop the hood up on the prop rod.
    • When working on any vehicle, always disconnect the negative terminal from the battery first. Often labeled on the cable or battery.
  2. 1996-2000 Honda Civic Headlight Bulb Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 1996-2000 Honda Civic Headlight Bulb Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the top bumper clips with the panel removal tool.
  3. 1996-2000 Honda Civic Headlight Bulb Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 1996-2000 Honda Civic Headlight Bulb Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screw/10mm(depending on year) bolt holding the bumper on. This will be located in the front wheel well on the passenger and driver side.
    • Repeat this step for the other side of the vehicle and pull the bumper down carefully.
  4. 1996-2000 Honda Civic Headlight Bulb Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 1996-2000 Honda Civic Headlight Bulb Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two bolts visible on the top of the headlight.
    • Remove the hidden screw facing towards the grille towards the bottom of the headlight.
    • Remove the other hidden bolt on the wheel well side of the headlight, same area as in step 3.
  5. 1996-2000 Honda Civic Headlight Bulb Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 1996-2000 Honda Civic Headlight Bulb Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the headlight assembly several inches outward.
    • Be careful not to yank on the wiring towards the rear of the headlight to prevent damage.
  6. 1996-2000 Honda Civic Headlight Bulb Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the connector on top of the rubber boot by squeezing the clip and carefully wiggling loose.
    • You do not need to remove the other connector to the left.
  7. 1996-2000 Honda Civic Headlight Bulb Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 1996-2000 Honda Civic Headlight Bulb Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rubber boot surrounding the headlight bulb housing.
  8. 1996-2000 Honda Civic Headlight Bulb Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 1996-2000 Honda Civic Headlight Bulb Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the retaining clip up releasing the headlight bulb.
  9. 1996-2000 Honda Civic Headlight Bulb Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully, pull the old bulb out of the headlight housing.
  10. 1996-2000 Honda Civic Headlight Bulb Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1996-2000 Honda Civic Headlight Bulb Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1996-2000 Honda Civic Headlight Bulb Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the new LED Headlight in the housing and latch the new headlight.
    • If replacing with a standard halogen bulb, the same procedures apply.
    • Test your new headlight bulbs and make sure they function properly. If they do not work at first, try cleaning off the connection mating your new bulb and its connector.
To reassemble your components, follow these instructions in reverse order.
John F. Kennedy
crwdns2935283:011/17/22crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
NO. There is plenty of room on the passenger side to get the clip and bulb changed without removing anything, and the drivers side you just pull up and move the power steering reservoir over and you have plenty of room there too.
Thomas Mulkey - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 118
crwdns2942667:0crwdne2942667:0 2,950
