An oil change should be performed every 5k miles and can easily be.
Follow this video tutorial by YouTuber NutzAboutbolts to do the job yourself.
crwdns2936621:0crwdne2936621:0
Locate the oil filter under the exhaust manifold in the front of the vehicle
Place the Lisle 63600 Oil Filter Tool over the filter, use an extension on the ratchet to reach around the hot manifold, and loosen the filter
Be careful not to burn yourself on the hot manifold.
Unscrew the oil filter and let it drain into the oil drain pan
Make sure the pan is aligned to catch oil from both the filter and drain plug.
Carefully remove the old oil filter
Clean the mating surface where the new filter will be installed
Ensure there are no old seals or debris that could affect the new filter's seal
Install the new oil filter by hand tightening it
Replace the old gasket on the drain plug with a new one, if necessary
