1986 Pontiac Fiero Headlight Motor Gear Replacement
  1. 1986 Pontiac Fiero Headlight Motor Gear Replacement, Headlight Motor Gear and Spacers: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1986 Pontiac Fiero Headlight Motor Gear Replacement, Headlight Motor Gear and Spacers: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1986 Pontiac Fiero Headlight Motor Gear Replacement, Headlight Motor Gear and Spacers: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open and prop the hood.
    • Disconnect the battery.
    • Disconnect the headlight from its housing by removing the four bolts with a 10mm socket and wrench.
    • Use the socket to hold one end of each bolt in place while using the wrench to loosen.
    • There are two bolts on the top and two bolts on the bottom.
    • Disconnect the headlight power cable that leads to the lightbulb, then remove the headlight from its housing to continue to disconnect the remaining wires.
  2. 1986 Pontiac Fiero Headlight Motor Gear Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1986 Pontiac Fiero Headlight Motor Gear Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1986 Pontiac Fiero Headlight Motor Gear Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the blue wire that leads to the motor, and the red wire harness that leads to the headlight relay.
    • Move the headlight to a clean working space.
  3. 1986 Pontiac Fiero Headlight Motor Gear Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the headlight from the housing and remember or take a picture of the orientation of the arm.
  4. 1986 Pontiac Fiero Headlight Motor Gear Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1986 Pontiac Fiero Headlight Motor Gear Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1986 Pontiac Fiero Headlight Motor Gear Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the motor from the headlight and remove the three screws around the motor securing it to the headlight casing, and the screws on the motor arm.
    • Use the 10mm for the screws on the casing and for the nut on the arm.
    • In this step you will use the 1/4 Allen wrench to hold the arm screw in place.
  5. 1986 Pontiac Fiero Headlight Motor Gear Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 1986 Pontiac Fiero Headlight Motor Gear Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the motor from the headlight casing and remove the last connection from the relay.
  6. 1986 Pontiac Fiero Headlight Motor Gear Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1986 Pontiac Fiero Headlight Motor Gear Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1986 Pontiac Fiero Headlight Motor Gear Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the arm with gentle but firm pressure, if the arm will not budge, hit it with a mallet/hammer to slide it off the rod.
  7. 1986 Pontiac Fiero Headlight Motor Gear Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 1986 Pontiac Fiero Headlight Motor Gear Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now you will need to remove the cover, you should see screws all around the motor casing.
    • Remove them using the 8mm wrench and Philips head screwdriver.
    • (alt)If the motor is still factory sealed, take a 1/8th drill bit and drill through the rivets holding the casing closed.
  8. 1986 Pontiac Fiero Headlight Motor Gear Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1986 Pontiac Fiero Headlight Motor Gear Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1986 Pontiac Fiero Headlight Motor Gear Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • When removing the cover you should see two gears, on meatal, one plastic, and a metal lever in between.
    • Remove both gears and the lever remembering their orientation or taking a picture.
  9. 1986 Pontiac Fiero Headlight Motor Gear Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1986 Pontiac Fiero Headlight Motor Gear Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1986 Pontiac Fiero Headlight Motor Gear Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Clean out the plastic gear casing as it will most likely be covered in plastic shavings and dried grease.
    • Clean the lever as it may also have what is left of a rubber spacer coating it and the residue will cause problems if left unchecked.
  10. 1986 Pontiac Fiero Headlight Motor Gear Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 1986 Pontiac Fiero Headlight Motor Gear Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Put new grease on a new plastic gear, then replace the old plastic gear in the motor.
  11. 1986 Pontiac Fiero Headlight Motor Gear Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 1986 Pontiac Fiero Headlight Motor Gear Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Put new rubber spacers in the far corners of the inside of the plastic gear.
  12. 1986 Pontiac Fiero Headlight Motor Gear Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Put in a lever and make sure it fits snugly and once you do put the metal gear on.
  13. 1986 Pontiac Fiero Headlight Motor Gear Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Put a resealing agent on the edges of the motor and close the casing again.
    • When closing the case there is a seal inside the top of the motor casing. use needle nose pliers or a flathead to hold it in place.
    • Do steps 1-7 backwards to reassemble and screws should come with the replacement kit if you took step 3 alt.
Sevin
crwdns2935283:002/24/25crwdne2935283:0
241 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 1-7, Kapoor Spring 2025 crwdns2935289:0Austin Community College, Team 1-7, Kapoor Spring 2025crwdne2935289:0
AUSTINCC-KAPOOR-S25S1G7
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 22
