1986-1993 Volvo 240 Front Struts Replacement
  1. 1986-1993 Volvo 240 Front Struts Replacement, Front Springs: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1986-1993 Volvo 240 Front Struts Replacement, Front Springs: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1986-1993 Volvo 240 Front Struts Replacement, Front Springs: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Jack up the front of the car and place it on jack stands.
    • Never work on or underneath a car that is only supported by a jack. The jack may slip or fail, resulting in serious injury or even death.
    • Use an impact wrench or tire iron to remove the five 19 mm lug nuts from the front wheel.
    • Pull the front wheel off the wheel lugs and set it aside.
  2. 1986-1993 Volvo 240 Front Struts Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1986-1993 Volvo 240 Front Struts Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1986-1993 Volvo 240 Front Struts Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a socket wrench or impact gun to remove the 15 mm nut on the front sway bar endlink.
  3. 1986-1993 Volvo 240 Front Struts Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1986-1993 Volvo 240 Front Struts Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1986-1993 Volvo 240 Front Struts Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The front brake lines are attached to the body by a small bracket near the strut.
    • Grab the front edge of the bracket with a pair of locking pliers.
    • Without the locking pliers to hold the bracket in place, it may twist back and forth. This twisting could fracture the rigid brake lines.
    • Remove the 12 mm bolt that holds the bracket in place with a socket wrench.
  4. 1986-1993 Volvo 240 Front Struts Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 1986-1993 Volvo 240 Front Struts Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a socket wrench or impact gun to remove the 19 mm tie rod end nut.
  5. 1986-1993 Volvo 240 Front Struts Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 1986-1993 Volvo 240 Front Struts Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place a tie rod end puller over the exposed threads of the tie rod end and turn the puller with a socket wrench to push the tie rod end out of the steering knuckle.
  6. 1986-1993 Volvo 240 Front Struts Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1986-1993 Volvo 240 Front Struts Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1986-1993 Volvo 240 Front Struts Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The ball joint is held to the control arm by three 18 mm bolts.
    • Remove the bottom two nuts with a breaker bar or long wrench.
    • Place a breaker bar over the gold nut on the bottom of the control arm.
    • The breaker bar alone will not be able to loosen the nut, since the bolt is free to rotate.
    • Place an 18 mm box end wrench over the bolt on top of the control arm.
    • Turn the breaker bar and the wrench in their respective counterclockwise directions to loosen and remove the third ball joint-to-control arm bolt.
  7. 1986-1993 Volvo 240 Front Struts Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place a jack underneath the ball joint to support it once you remove the 3 ball joint-to-control arm bolts.
  8. 1986-1993 Volvo 240 Front Struts Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1986-1993 Volvo 240 Front Struts Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1986-1993 Volvo 240 Front Struts Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the hood and locate the three strut mounting bolts on the strut tower.
    • Make an alignment mark on the shoe at the dimple in the top of the strut tower before removing the mounting nuts.
    • Use a ratcheting socket wrench or impact wrench with a 13 mm deep socket to remove the three nuts.
  9. 1986-1993 Volvo 240 Front Struts Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slowly lower the jack and guide the strut assembly down and out of the car.
  10. 1986-1993 Volvo 240 Front Struts Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1986-1993 Volvo 240 Front Struts Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1986-1993 Volvo 240 Front Struts Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place spring compressors on opposite sides of the spring.
    • Make sure you are using spring compressors that are meant for MacPherson struts. Internal-type spring compressors will not work.
    • Alternate tightening the spring compressors evenly until you are able to move the entire spring up and down.
  11. 1986-1993 Volvo 240 Front Struts Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1986-1993 Volvo 240 Front Struts Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1986-1993 Volvo 240 Front Struts Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an impact wrench to remove the 24 mm nut at the top of the strut assembly.
    • Remove the strut mount from the strut assembly.
  12. 1986-1993 Volvo 240 Front Struts Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 1986-1993 Volvo 240 Front Struts Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the upper spring seat and pull the spring off the strut assembly.
    • If you are installing new springs you will need to remove the spring compressors. Loosen each spring compressor evenly, alternating from side to side until they are off the spring completely.
    • When installing new springs you will need to compress them with the spring compressors before placing them on the strut assembly.
    • If you are reinstalling the same springs you may keep the compressors in place until it is time to reassemble the suspension.
  13. 1986-1993 Volvo 240 Front Struts Replacement, Front Struts: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rubber bump stop from the strut assembly.
  14. 1986-1993 Volvo 240 Front Struts Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a large adjustable wrench or pair of groove joint pliers to remove the strut gland nut.
  15. 1986-1993 Volvo 240 Front Struts Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab the top of the strut and pull it out of the strut assembly.
crwdns2935229:015crwdne2935229:0
David Hodson
crwdns2935283:004/13/10crwdne2935283:0
154,040 crwdns2915208:0crwdne2915208:0
crwdns2935297:0127crwdne2935297:0
crwdns2947412:011crwdne2947412:0
This is so helpful. When I did this for the first time a while back, it took me and a buddy almost 9 hours to complete it. Now that I'm changing the other side, I decided to see if there were any guides online and WOW THIS IS SO HELPFUL. YOU ARE AMAZING FOR DOING THIS!!!
Parth Doshi - crwdns2934203:0crwdne2934203:0
You note years 86-93. I have an 84 244 Turbo that I want to swap front strut assembly from 90 240. Will this work?
jerrod.slaughter - crwdns2934203:0crwdne2934203:0
Just finished putting new struts and springs on 1990 Volvo 240 wagon. Your pictures and details were very helpful. It would be great if the breaklines could be removed from the strut boot.
Eric Zeko - crwdns2934203:0crwdne2934203:0
thanks for the help you been most helpfull
Peter Cameron - crwdns2934203:0crwdne2934203:0
IF you remove the brake caliper and disc it makes the strut assembly so much lighter and easier to handle.
Jo Black - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 74
crwdns2942667:0crwdne2942667:0 27,231
