1986-1993 Volvo 240 Front Brake Caliper Replacement
  1. 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Wheels: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Wheels: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Wheels: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Jack up the front of the car and place it on jack stands.
    • Never work on or underneath a car that is only supported by a jack. The jack may slip or fail, resulting in serious injury or even death.
    • Use an impact wrench or lug wrench to remove the five 19 mm lug nuts from the front wheel.
    • The wheel lug nuts should be torqued to 85 ft-lbs when the wheels are put back on the car.
    • Pull the front wheel off the wheel lugs and set it aside.
  2. 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Brake Calipers: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Brake Calipers: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 15 mm box end wrench to remove the two bolts on the back of the brake caliper.
  3. 1986-1993 Volvo 240 Front Brake Caliper Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 1986-1993 Volvo 240 Front Brake Caliper Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the brake caliper off the rotor and set it aside.
    • Place the caliper on some type of support so that you do not put too much strain on the brake hose.
  4. 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Brake Caliper: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Brake Caliper: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an open-end wrench to loosen the 11 mm fitting where the brake hose attaches to the caliper.
    • Brake fluid will come out of the loosened brake hose. You should keep a bucket or pan nearby to collect it.
    • Be careful when handling brake fluid, as it may strip paint and dissolve some plastics.
    • Detach the brake hose and remove the brake caliper.
    • When you install the new calipers you will need to bleed the brakes to remove any air from the brake fluid lines.
David Hodson
crwdns2935283:004/13/10crwdne2935283:0
150,500 crwdns2915208:0crwdne2915208:0
crwdns2935297:0127crwdne2935297:0
crwdns2942667:0crwdne2942667:0 6,256
