1979 Ford F-150 Needle and Seat Replacement
    • Put your vehicle in park and turn it off.
  1. 1979 Ford F-150 Needle and Seat Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open hood of your vehicle and locate the air filter.
    • Remove screw attached to air filter assembly. Remove air filter unit.
  2. 1979 Ford F-150 Needle and Seat Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the needle and seat screw.
  3. 1979 Ford F-150 Needle and Seat Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use 3/8 wrench to hold the bolt in place. Now use the flat head screw driver to unscrew the screw.
    • Twist counterclockwise with flathead screwdriver.
  4. 1979 Ford F-150 Needle and Seat Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove screw and set it to the side.
  5. 1979 Ford F-150 Needle and Seat Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use 3/8 wrench to remove nut.
  6. 1979 Ford F-150 Needle and Seat Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the 7/16 wrench and twist the needle and seat counterclockwise.
  7. 1979 Ford F-150 Needle and Seat Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the needle and seat.
  8. 1979 Ford F-150 Needle and Seat Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert your new needle and seat. Twist clockwise until about half the threads are in the carburetor.
    • To reassemble, go in reverse order from step 10.
    • To replace screws that were removed, twist clockwise until the screws have a tight hold.
  9. 1979 Ford F-150 Needle and Seat Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once everything is reassembled, turn on the car.
    • If the car is making a high pitched idling noise, you may need to adjust needle and seat tighten (clockwise) to reduce rpm and loosen (counterclockwise) to increase.
Chris McBride
crwdns2935283:011/10/21crwdne2935283:0
205 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 111
