1976 Mercedes-Benz 230.6 Oil and filter
  1. 1976 Mercedes-Benz 230.6  Oil and filter, Oil and Oil filter: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1976 Mercedes-Benz 230.6  Oil and filter, Oil and Oil filter: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1976 Mercedes-Benz 230.6  Oil and filter, Oil and Oil filter: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • We'll be working on my old Mercedes today, changing the Oil and Filter
    • Pop the bonnet, or in USA "pop the hood", in RHD cars, the catch is on the left side next to the door
    • It's two-hands to open the actual bonnet as there are 2 ajar catches on this model - one on either side near the sides of the front of the bonnet/hood
  2. 1976 Mercedes-Benz 230.6  Oil and filter, Jacking points: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1976 Mercedes-Benz 230.6  Oil and filter, Jacking points: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1976 Mercedes-Benz 230.6  Oil and filter, Jacking points: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • I put my hydraulic jack in the centre of the front of the sub-frame
    • I put the jack stands under the frame/unibody box sections
    • I use cardboard instead of a creeper - more leverage, and easy clean up
  3. 1976 Mercedes-Benz 230.6  Oil and filter, Removing the drain bolt: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1976 Mercedes-Benz 230.6  Oil and filter, Removing the drain bolt: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1976 Mercedes-Benz 230.6  Oil and filter, Removing the drain bolt: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • I used a 14mm hex or "Allen" key
    • It appears some of the previous oil-changers over the last 40 years did not have the correct tool as there are vise-grip marks on the bolt
    • See the oil flow
  4. 1976 Mercedes-Benz 230.6  Oil and filter, Remove old filter: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1976 Mercedes-Benz 230.6  Oil and filter, Remove old filter: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1976 Mercedes-Benz 230.6  Oil and filter, Remove old filter: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Check your new filter etc, I used Hengst E117H D07, but last time I used Mann H720X, both kits came with new o-rings and copper crush-washers
    • The oil filter is a cartridge-in-housing type located on the left-side of the engine block
    • I only had room for a wrench/spanner and had to work it a bit before loosening it with my fingers
  5. 1976 Mercedes-Benz 230.6  Oil and filter, Drain filter housing and old filter: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1976 Mercedes-Benz 230.6  Oil and filter, Drain filter housing and old filter: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1976 Mercedes-Benz 230.6  Oil and filter, Drain filter housing and old filter: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before removing the oil filter housing fully, move your catch pan under the area to catch the mess
    • Clean around the housing mounting plate area with a clean-ish rag, I use 2 grades of rag, the super-oily one first to pick up the bulk of the oil, then a cleaner rag after
    • I used a small pick to pull out the old o-ring - also check you don't misplace the washer on the long bolt
  6. 1976 Mercedes-Benz 230.6  Oil and filter, Clean out the housing and install new filter: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Clean out the filter housing with your rags etc, then install a new o-ring if your kit came with one
    • Oil the new o-ring for re-installation
    • Place the new filter cartridge in the housing and insert the bolt with washer on it
    • Hold the bolt in and thread your hand down next to the block, lucky these old cars have heaps of space to work/see
    • Tighten the bolt down, but don't over-tighten as it's only a cast-metal housing
  7. 1976 Mercedes-Benz 230.6  Oil and filter, Ensure your drain bolt and filter are tight: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 1976 Mercedes-Benz 230.6  Oil and filter, Ensure your drain bolt and filter are tight: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Tighten your drain bolt and clean the area around the bolt with a rag
    • Check the area for leaks after filling
    • As you can see, my old filter was a Mann H720
  8. 1976 Mercedes-Benz 230.6  Oil and filter, Lower the car: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 1976 Mercedes-Benz 230.6  Oil and filter, Lower the car: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the car up from that front sub-frame lifting area and remove your jack-stands
    • Then gently lower the car so it's level for filling
  9. 1976 Mercedes-Benz 230.6  Oil and filter, Fill the car: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 1976 Mercedes-Benz 230.6  Oil and filter, Fill the car: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 1976 Mercedes-Benz 230.6  Oil and filter, Fill the car: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • I usually clean around the Oil fill cap with a rag
    • The dip-stick on this engine is next to the spark-plug wires
    • I used a stubby big-mouth funnel
    • I used 20W-50 for this old car, it needed about 5.5L or so
Fresh oil and filter installed :)
Gaspard Leon
crwdns2935283:004/24/10crwdne2935283:0
2 831 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 1,899
