12-inch Sprinkler Head Replacement
  1. 12-inch Sprinkler Head Replacement, 12-inch Sprinkler Head: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 12-inch Sprinkler Head Replacement, 12-inch Sprinkler Head: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 12-inch Sprinkler Head Replacement, 12-inch Sprinkler Head: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Dig and remove dirt around the existing sprinkler head and several inches around connected PVC.
    • Place the dirt in 5 gallon the buckets or on the surface near the hole.
    • Dig until the hole is at least 14 inches below the PVC pipe allowing room for the flex riser.
  2. 12-inch Sprinkler Head Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 12-inch Sprinkler Head Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 12-inch Sprinkler Head Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rinse all around the sprinkler head and PVC with water.
    • This will allow for a clean installation of the new sprinkler parts and keep the dirt from entering the new parts.
  3. 12-inch Sprinkler Head Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 12-inch Sprinkler Head Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 12-inch Sprinkler Head Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the old sprinkler head and riser.
    • Turn counterclockwise until the old sprinkler head and or riser is removed.
    • Rinse area for clean installation.
  4. 12-inch Sprinkler Head Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 12-inch Sprinkler Head Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 12-inch Sprinkler Head Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • For this step, wrap 4 threaded ends with Teflon tape: both ends of the flex riser and one end of each swing joint elbows.
    • Wrap Teflon tape clockwise around the threaded part of each of the above-mentioned sprinkler connections.
    • Put three complete layers of tape on each of the threaded ends. This will allow for a tighter and secure fit.
  5. 12-inch Sprinkler Head Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 12-inch Sprinkler Head Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 12-inch Sprinkler Head Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Screw clockwise, the new Teflon wrapped the threaded part of an elbow, into the pipe in the ground.
    • This is the location of the old sprinkler head and riser.
    • Confirm that the part is installed snugly and not cross-threaded.
    • Caution: Do not over tighten.
  6. 12-inch Sprinkler Head Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 12-inch Sprinkler Head Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Screw the threaded end of the elbow onto the 12" sprinkler head.
  7. 12-inch Sprinkler Head Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 12-inch Sprinkler Head Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 12-inch Sprinkler Head Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Confirm that Teflon tape has been applied to both threaded ends.
    • Screw one end of the blue flex tubing onto the elbow in the previous step.
    • Screw the other end of the flex tubing onto the last remaining elbow.
    • Caution: Confirm that the part is installed snugly and not cross-threaded. Do not over tighten.
  8. 12-inch Sprinkler Head Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 12-inch Sprinkler Head Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 12-inch Sprinkler Head Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lower the 12-inch sprinkler head and flex tubing down into the hole.
    • Adjust the new sprinkler head so it is level with the sidewalk or surface.
    • Adjust flex tubing as necessary so that there are no kinks and that the joints are still tight.
  9. 12-inch Sprinkler Head Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Test the new parts to confirm that there are no leaks.
    • Guard your eyes and other things that you don't want to get wet.
  10. 12-inch Sprinkler Head Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 12-inch Sprinkler Head Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 12-inch Sprinkler Head Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the sprinkler head in place, vertically, while carefully putting the dirt into the ground by hand. Using your hands allows for a gentle pressure on the sprinkler head versus using a tool that could crack or break it.
    • Add dirt in layers, compressing the dirt by hand, around the sprinkler head.
    • Do not compress the dirt too much, as the tubing can be crushed.
  11. 12-inch Sprinkler Head Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 12-inch Sprinkler Head Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn on the sprinkler system.
    • At this point full water flow should come out of the new sprinkler head.
    • If the flow is good, adjust the nozzle direction and radius by turning the nozzle head and shaft.
    • Check water pressure and nozzle lift after landscaping has returned around sprinkler head.
PATRICIA ANN FOURNIER
crwdns2935283:009/27/24crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
CSU Sacramento, Team 1-1, Laflen Fall 2024 crwdns2935289:0CSU Sacramento, Team 1-1, Laflen Fall 2024crwdne2935289:0
CSUSAC-LAFLEN-F24S1G1
crwdns2942667:0crwdne2942667:0 293
