01. Tools
crwdns2869540:0crwdne2869540:0: 8
6
8
8
8
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: crwdns2931273:0crwdne2931273:0
crwdns2955970:0crwdne2955970:0: crwdns2937585:0crwdne2937585:0
01. Tools
    1. 01. Tools, No power tools: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Do not use power tools for the whole assembly or you might damage hardware. Always use hand tools.
      • Tightening torque values recommended:
      • Max 4.5Nm for M5 screws on metal to metal assemblies (e.g. joining plate on an extrusion).
      • Max 1.5-2Nm for M5 screws on printed part to metal (e.g. y_rod_holder.stl on extrusion).
    2. 01. Tools, Mandatory tools: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • This step and the next one list the mandatory tools you need to build the Bear frame.
      • Small pliers with cutting capabilities
      • Hex key 1.5mm for MK2(S) and MK2.5(S) only, not useful for MK3(S).
      • Hex key 2mm.
      • Hex key 2.5mm. Ball end would be very useful.
      • Hex key 3mm.
      • Spanner 5.5mm
      • Slotted screwdriver #1
    3. 01. Tools, Mandatory tools: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • This step and the previous one list the mandatory tools you need to build the Bear frame.
      • Having a quality square will help you to build the Bear precisely. We recommend a 200mm long machinist precision square, ideally with standard DIN 875 / BS 939 (any grade).
      • If you don't have such a square or want to use a lower quality one, check these videos on how to test and fix your square:
      • How to Square a Square by Wesley Treat: https://youtu.be/FNpAQHrNpNU
      • How to Square a Square and Make it True by Wood By Wright: https://youtu.be/enEYzTXg2Jg
      • Caliper, 150mm long minimum. If you don't have a caliper you can use a steel ruler. (A vernier caliper is generally more accurate than a digital caliper, at the same price point.)
    4. 01. Tools, Optional tools: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • This step and the next one list the optional tools that can be helpful during assembly. You can build the Bear frame perfectly without them.
      • Sorry for this extra list, we love tools...
      • A long caliper of 200mm or more helps to align the Y axis smooth rods spacing on any "Prusa type" printer.
      • A general purpose clamp will facilitate the squaring of the frame when using a machinist square.
      • Tweezers are always useful :)
      • You can add a dab of blue Loctite #243 to the screws during assembly to prevent them from unscrewing.
      • An 8mm drill bit or 8mm reamer can be useful in case the smooth rods holes on Z axis are a bit too tight.
    5. 01. Tools, Optional tools: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 01. Tools, Optional tools: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • This step and the previous one list the optional tools that can be helpful during assembly. You can build the Bear frame perfectly without them.
      • Files and deburring tool can be helpful to clean the printed parts.
      • It is good practice to re-grease the bearings during the assembly.
      • We recommend the use off a lithium based lubricant that has a viscosity between 50 and 100mm2/s at 40 °C, NLGI class 2 and a thermal resistance of 100°C or more.
      • A torque tool can be useful to ensure you apply max torque without damaging hardware.
      • We recommend max 4.5Nm for the metal to metal assemblies (e.g. joining plate on an extrusion) and max 1.5-2Nm for printed parts (e.g. y_rod_holder.stl on extrusion).
    6. crwdns2952109:0crwdne2952109:0
    7. crwdns2952109:0crwdne2952109:0
Greg Bear
crwdns2935283:011/04/26crwdne2935283:0
8,773 crwdns2915208:0crwdne2915208:0
crwdns2935297:035crwdne2935297:0
crwdns2936753:030crwdne2936753:0 8
crwdns2959996:0crwdne2959996:0 8
