Use this guide to remove and replace the Nokia 6010's logic board.
Press the small tab on the bottom of the back of the phone.
Push the back case upward towards the power button. The back case will then pop off.
Lift the battery near the bottom and pry up.
With one hand, press the ridged tab near the visible side of the SIM card.
Slide the card out with your other hand.
Grip the phone on either the sides, the top, or the bottom.
Pull the front case away from the rest of the phone.
Lift the keypad away from the body of the phone.
Remove the six screws around the front of the phone body with a T6 screwdriver.
Insert your finger underneath the speaker piece and pry away from the phone body.
Slide the rubber power button away from the body of the phone.
Insert a finger between the phone body and logic board.
Pull the board away gently.
