要更换或取出相机吗?来看看这个吧。
如果您的前盖板玻璃碎裂,请保持它现在的状况,并在修理时贴上胶带防止人身伤害。
把透明胶带粘满整个前面板
从设备底部拆下两个Phillips #00 螺丝
Is the camera (lens) available for separate purchase? If so, can we upgrade the camera? like 3mgp or 5mgp? Thanks
Thanks! I followed the instructions and it worked perfectly. Don't forget to turn your phone off beforehand!
crwdns2936937:0Shawncrwdne2936937:0
Also should note that the tab that you have to flip in step six is black, and not white (my colors were reversed from the pic, which is not a 3G).
从吸盘上取下金属环。 抓住吸盘底座更容易,更安全。
使用吸盘轻轻拉起iPhone显示屏底部。
向上旋转屏幕到大约90度左右。 这将更容易断开其他排线。
用撬棒翘起“2号”排线
排线“3”由FPC型连接器固定。 在取下排线之前,必须先打开这个连接器:用一根塑料棒将白色/黑色塑料片向上翻起来,把剩下的带状电缆固定到位。 塑料片将向上旋转90度,松开排线。
将排线从连接器中取出,然后从iPhone上卸下屏幕。
将SIM针或回形针插入耳机插孔旁边的孔中。
按下工具,直到SIM卡托盘弹出。
抓住SIM卡托盘并将其从iPhone中取出。
拆下下面8颗螺丝
主板上的5颗2.3毫米的十字 #00 螺丝
主板上固定相机的2颗2.3毫米的十字 #00 螺丝
1颗在“Do Not Remove”标签下的螺丝
使用撬棒轻轻撬起相机,并从其后面板的外壳。由于相机排线位于主板下层,相机无法完全移除。
用撬棒分离相机和主板
There is a little silver clip that needs to go on top of the camera to secure it. If this is not done correctly the camera will not work. Ensure the small silver clip is secured the exact same way as you saw it initially, and ensure the cable is fitted correctly.
Can we get a picture or video of this. I tried to fix my iPhone using this guide and your comment is exactly why my camera will not work. It would be very helpful to see the position of the clip the way it is supposed to be connected.
Also the screw that holds the camera clip down is held by one of the small screws,
THE ONLY ONE WITH THREAD ALL THE WAY UP TO THE HEAD, the others only only 3/4's threaded. The correct position of that clip is in picture 11, I think.
Chewtah -
要重新组装您的设备,请按照相反的顺序执行这些指示。
crwdns2935229:065crwdne2935229:0
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Thanks for an awesome guide. On mine after getting it reassembled the camera had a green screen. The cable for the camera got slightly disconnected while putting things back together. I'm thinking because the one I got the ribbon was kinda stiff and straight when it had to fold to go back in properly it came slightly unplugged. I just squashed around the camera corner of the case pinching it, of course not to hard, and it came up and works perfectly now. Thanks again, my friend sold me this iphone cheap cause the camera was broke. Thanks to you its good as new.
