在更换你的屏幕之前,需要先取出电池。
在进行更换前,请确保你的手机已经关机。
使用翘片,手指甲,或者是撬棒把外壳打开。
用撬棒起最上层与充电口的连接。
沿着排线慢慢撬起胶水与排线的连接。
在下一接口处停下来。
在主板左下角找到后置摄像头接口。
如果表面有黑色胶带,请用镊子小心剥除。
用工具小心撬起,然后使其向手机下侧。
翻转手机,使手机屏幕向上。
在手机屏幕上放好已经加热好的iOpener以加热屏幕胶。
稍等几分钟。
用一个翘片慢慢的将屏幕和手机分离。
确保每一个边缘和角落都已被成功分离。
重新组装手机,只要倒序执行步骤即可
重新组装手机,只要倒序执行步骤即可
crwdns2935229:065crwdne2935229:0
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
crwdns2944067:029crwdne2944067:0
Screen is available on internet but without frame and buttons. I bought one of those so the only pb i had was to separate capacitive buttons and fingerprint scanner from the screen. i had to separate the black plastic frame from the screen too. It takes me around 2 hours to do it but now my OP2 works with a brand new screen. Changing screen on OnePlus2 is doable and cost around 100€ but you have to be careful and patient.
Is the screen working properly??
It's the glue on the back of the screen or on the frame? Do you need to apply new glue?
krugern -
Hi, can you recommend the place where you bought your screen?
You need glue when installing a new digitizer?
