Wacom Cintiq Pro 13 Disassembly
crwdns2933315:02crwdne2933315:0 crwdns2934263:00crwdne2934263:0 |
How to change the screen? |
crwdns2933313:01crwdne2933313:0 crwdns2934263:01crwdne2934263:0 |
Can I make the usb power to skip the button to turn on.? |
Technical Specs and Compatible Accessories
Display:
- 13” Full HD (1920x1080) IPS matte screen with wide color gamut, 87% of Adobe RGB
Ports:
- 3x USB type C port
- 1x Audio 3,5mm jack
- 1x USB 3.0 Card Reader
Compatible Pens:
- Wacom Pro Pen 2
- Wacom Pro Pen Slim
- Wacom Pro Pen 3D
- Wacom Pro Pen (KP503E)
- Wacom Grip Pen (KP501E)
- Wacom Art Pen (KP701E2)
- Wacom Classic Pen (KP300E2)
- Wacom Airbrush Pen (KP400E2)
Compatible Power Adapters:
- Wacom 100W USB-C Power Adapter ADP-100PB
- Wacom 45W USB-C Power Adapter ACK4281401
- Any other USB-C Power adapter with 20V output (at least 45W) (Commonly sold as Laptop Power Adapters)
Connection types and compatible adapters:
USB-C to USB-C connection
- In order to use it with USB-C to USB-C connection, host device (PC/Mac) must support USB-C DisplayPort Alternate Mode
Displayport/HDMI to USB-C
By using
- Wacom Link (Mini Displayport)
- Wacom Link Plus (Mini Displayport [up to 4K] and HDMI [up to QHD] )
Warning - most USB-C adapters allow only USB-C host (PC/Mac) to DisplayPort/HDMI monitor connection, not in reverse as required by Cintiq 13/16 and other USB-C monitors
Extra information
- Can be used as drawing tablet with touch functionality by connecting USB 2.0 to USB-C cable and power adapter directly to any tablet USB-C port, and not connecting any display inputs
Components and Servicing
Extra servicing information
- “Power button and touch display controls” board is placed under front glass, requiring front glass removal or cutting plastic casing inside the tablet to remove and replace it
- Casing is glued using very strong adhesive, making it very hard to open the device without any damage
- Audio jack board is separated from the mainboard, making it soldering-free replacement part.
- Most firmware is stored in 25 SPI Flash EEPROM chips, and can be reprogrammed using cheap BIOS programmers, eg. CH341A
- Pen firmware is stored in Wacom Pen Controller chip, and there is no easy method to fix it if it has failed.
- Display used in this device is a 13” inch laptop-like display and uses 30-pin edisplayport connector
- LCD Display used in this tablet is a custom part, with pen digitizer as one of it's layers, just under backlight layers. Replacement will require same model of LCD Panel to be used.
- LCD Display is glued to the touch digitizer layer, which then, is glued, to the front glass.
Mainboard components
- Realtek RTD2786B LCD scaler (handles both display and audio) (+ SPI Flash EEPROM firmware chip)
- 128MB DDR3 memory
- Kinetic STDP4028 LVDS to DisplayPort transmitter (+ SPI Flash EEPROM firmware chip)
- Three USB-C TI TPS65982 controllers (+ 3x SPI Flash EEPROM firmware chips)
- Genesys GL3224 USB 3.0 Card Reader controller (+ SPI Flash EEPROM firmware chip)
- Two USB 3.0 Hubs
- Wacom Pen Controller chip
- FTDI FT232 USB to UART controller
Internal components
- Mainboard 4H.3GCA8.A00
- Wacom Pen digitizer boards (PWB-C800-C + PWB-C929-C)
- Audio jack board
- Power button board with touch controls
- BOE NV133FHM-A52 Display (May vary from unit to unit)
