crwdns2935069:020crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
PT2A
Background
The Wacker Neuson PT2A is a gasoline-powered water removal pump, used for excavation sites, flooded homes or basements, construction sites, and other general-purpose applications. The Wacker Neuson comes in two variations of engine models, the GX160 model has a fuel capacity of approximately 3.1 to 3.6 US quarts of unleaded gasoline and 0.6 liters of oil. The PT2A has a pumping rate of 770 gallons per minute, and its base operating engine speed is 3,500 revolutions per minute.
The Wacker Neuson PT2A handles solids up to 25 mm (1 inch) in diameter and features a durable tubular steel frame for protection. The PT2A's weight of approximately 30 kg (66 lbs.) and compact dimensions make it designed for easy transport and operation on construction sites and during emergencies. The pump can move up to 2,900 liters per minute (770 gallons per minute) and lift water to 30 meters (98 feet), making it ideal for quick water removal. Wacker Neuson PT2A Pump Repair is easy due to its parts availability.
Identification
The Wacker Neuson PT2A can be identified by its bright yellow transport bars lining the outside of the tool. The Wacker Neuson Honda Engine has an engine block made of gray cast iron. There are multiple stickers with the company name on the tool. The PT2A has a large "W" in gray and red coloring. Two inlet and outlet ports face out on the front and right sides of the PT2A.
Technical Specifications
Dimensions:
  • L x W x H: 24 x 18.9 x 18.2 (in.)
  • Suction Diameter: 2 (in.)
  • Maximum Head Pressure: 98 ft (30 meters)
  • Suction Lift: Up to 26 ft (8 meters)
Operation:
  • Cylinder Capacity: 9.9 (in³)
  • Standard (Operating power): SAE J1349
  • Cylinder: 1 Piston
  • Operating weight: (110 lb.)
  • Inlet Size: 2 inches (50 mm)
  • Outlet Size: 2 inches (50 mm)
Engine:
  • Engine: Air-cooled/Naturally Aspirated
  • Manufacturer: Honda
  • Maximum Operating Speed (rpm): 3,500 1/min
  • Maximum Engine Speed (rpm): 3,600 1/min
  • Oil Capacity: 0.62 US quarts (0.6 liters)
  • Fuel Capacity: 3.1 (US qt.) (2.9 liters)
  • Fuel Type: Gasoline
  • Max. Power: 4.8hp
  • Fuel consumption (US gal/h): 0.45
  • Runtime (h): 1.8
Additional Information
Engine: Honda GX160UT2
Wacker Neuson PT2A DHS Technical Specifications
Wacker Neuson PT2A DHS Parts Manual
Wacker Neuson PT2A Store Page
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 88
crwdns2942667:0crwdne2942667:0 1,623
