crwdns2911028:0crwdne2911028:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
Function of the device: provides a consistently clear view of a patient's airway, enabling quick intubations.
Function of the page: information and guides on how to repair and clean the device; as well as information on the specifications and logistics of the device.
Troubleshooting
For additional help on the Verathon Intubation System, check out the device’s operations and maintenance manual which can be found attached in the Additional Information section.
Background and Identification
The Verathon Intubation System (stat sizes: 0, 1, 2, 2.5, 3, and 4) was released to the public in August 2017 as a device used during procedure when one can't breathe on their own. The doctor puts a tube down their throat and into the windpipe to make it easier to get air into and out of the lungs. By connecting this device to its monitor through the designated video cables, medical professionals can get a clear and consistent view of the airway to help enable rapid and accurate intubation.
The Verathon Intubation System varies in weight according to the size of laryngoscope used. The Glidescope Verathon Laryngoscopes are available in the following formats:
  • GlideScope Titanium Reusable video laryngoscopes
  • GlideScope Spectrum Single-Use video laryngoscopes
  • Glidescope AVL Video Batons for use with Single-Use GVL Stats (blades)
  • GlideScope Video Baton 2.0 for use with Single-Use GVL Stats (blades)
The titanium reusable video laryngoscope devices consist of durable/lightweight titanium, which help enable low-profile blade designs for optimized maneuverability and working space. The video laryngoscope is connected to the video monitor via a reusable video cable. Titanium reusable video laryngoscopes are available in a uniquely angulated LoPro style, and in Mac style as well.
The Spectrum single-use video laryngoscopes are fully disposable video laryngoscopes that integrate the latest advancements in lighting technology to optimize image brightness and clarity throughout the intubation process. Spectrum single-use video laryngoscopes are connected to cart-based video monitors via a Smart Cable and are available in a uniquely angulated LoPro style, and in Miller and Mac styles as well.
The video batons and stats are reusable video batons that combine a high-resolution, full-color digital camera with an integrated LED light source and reveal anti-fog feature. Video batons are connected to cart-based video monitors via a permanently-integrated video cable (AVL Video Batons), or a separate Smart Cable (Video Baton 2.0). Video batons are available with a choice of two sizes and are designed to be used with single-use GVL Stats. GVL stats are offered in a comprehensive range of sizes, allowing clinicians to meet the particular requirements of a wide range of patients.
Technical Specifications
The full device is split up these parts with their specifications found below:
Portable Video Monitor (NTSC Color Video - 320 x 240 pixel 7” LCD TFT Panel)
  • Height: 6.57 in / 167 mm
  • Width: 8.15 in / 207 mm
  • Depth: 3.27 in / 83 mm
  • Weight: 3.10 lb / 1.4 kg
Mobile Stand
  • Base height: 4.925 in / 12.5 cm
  • Base weight: 5.5 lb / 2.5 kg
  • Base diameter: 24 in / 61 cm
  • Pole height range: 295.-47 in / 75-119 cm
  • Pole weight: 1.5 lb / 0.7 kg
IV Pole Mount
  • Weight: 2 lb / .9 kg
  • Arm Length: 10.63 in / 27 cm
  • Width: 2.44 in / 6.2 cm
GVL 5
  • Tip to front of handle: 4 in / 102 mm
  • Thickness (height) at camera: .55 in / 14 mm
  • Width of camera: 1.06 in / 27 mm
  • Blade length in front of camera: 2.4 in / 61 mm
  • Max blade width in front of camera: 1.06 in / 27 mm
GVL 4
  • Thickness (height) at camera: .6 in / 14.5 mm
  • Width of camera: .7 in / 7 mm
  • Blade length in front of camera: 2.1 in / 52 mm
GVL 3
  • Tip to front of handle: 3.2 in / 82 mm
  • Max blade width in front of camera: .75 in / 19 mm
GVL 2
  • Thickness (height) at camera: .57 in / 14.5 mm
  • Width of camera: .71 in / 18 mm
  • Blade length in front of camera: 1.4 in / 36 mm
  • Max blade width in front of camera: .63 in / 16 mm
GVL Stat 4
  • Tip to front of handle: 3.7 in / 95 mm
  • Thickness (height) at camera: .63 in / 16 mm
  • Width at camera: .78 in / 20 mm
  • Blade length in front of camera: 2.1 in / 53 mm
  • Max blade width in front of camera: 1.1 in / 27.5 mm
GVL Stat 3
  • Tip to front of handle: 3.15 in / 80 mm
  • Width at camera: .63 in / 16 mm
  • Blade length in front of camera: 1.46 in / 37 mm
  • Max blade width in front of camera: .83 in / 21 mm
GVL Stat 2
  • Tip to front of handle: 2 in / 51 mm
  • Thickness (height) at camera: .34 in / 8.7 mm
  • Width at camera: .43 in / 10.9 mm
  • Blade length in front of camera: 1.10 in / 28 mm
GVL Stat 1
  • Tip to front of handle: 1.50 in / 38 mm
  • Width at camera: .39 in / 9.9 mm
  • Blade length in front of camera: .59 in / 15 mm
  • Max blade width in front of camera: .51 in / 13 mm
Cobalt Video Baton 3-4
  • Length: Camera tip to SS ring: 4.1 in / 104.1 mm
  • Height of camera: .42 in / 10.7 mm
  • Width of camera: .43 in / 10.9 mm
  • Cable length: 66 in / 1676 mm
  • Weight: 6.3 oz / 180 g
Cobalt Video Baton 1-2
  • Length: Camera tip to handle (flexible tube): 1.57 in / 40 mm
  • Height of camera: .236 in / 6 mm
  • Width of camera: .276 in / 7 mm
  • Cable length: 69 in / 1756 mm
  • Weight: 4.6 oz / 130 g
Verathon Official Product Site
Medscape On the Importance of Intubation
Verathon GlideScope Video LaryngoScopes User Manual
Verathon GlideScope Titanium Reusable and Spectrum Single-Use Operations and Maintenance Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 39
crwdns2959996:0crwdne2959996:0 981
