crwdns2862670:0crwdne2862670:0
This wiki does not have a summary. Help improve this page by writing one!
crwdns2935069:02crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
HD6100
Background and Identification
US Steam is a business started in 1992 that sells commercial steam cleaners made in Italy. The US Steam Eagle (also known by the model number US6100) is a popular steam cleaner designed to clean tile & grout, stains, upholstery, and grease. This model heats up quickly and features a separate fill tank so you can refill the machine while the remaining water is still hot.
US Steam recommends that you only use plain tap-water without added chemicals to help preserve the machine. They also describe a descaling procedure in the manual that should be performed to clean the machine if it takes more than 10 minutes to heat up. This should remove calcium deposits in the machine that are left by the hot water.
You can identify this model by looking by looking at the serial tag on the bottom of the machine.
Technical Specifications
Power Supply
  • 120 V, 60 Hz
Pressure
  • 6 bar / 90 psi
Max Temperature
  • 325 °F
Boiler Volume
  • 1 L = 1/4 gallon
Reservoir Tank Capacity
  • 2 L = 1/2 gallon
Boiler Power
  • 1800 W
Ready Time
  • 8 minutes
Dimensions L x W x H
  • 19" x 16" x 36"
Net Weight
  • 28 lbs with accessories
Power Cord Length
  • 12 ft
Unlisted Parts Information
Thank you for reviewing the US Steam Schematics. For all repair parts not currently listed on the schematics, please follow these steps for each unit you need to send for repair:
  1. Read Instructions: Click on the Repair Form Link https://ussteam.net/repair/ Make sure to read all the instructions carefully.
  2. Complete the Form: Fill out the form at the bottom of the page.
  3. Drain the Steamer: Ensure the steamer is fully drained before shipping.
After submitting your request, you will receive a confirmation email with your RMA number, followed by another email containing your shipping label. Please ensure your submission goes through successfully.
*After submitting your request, you can expect a response within 48hrs of the request.
Additional Information
Home Depot Rental
User Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 73
crwdns2936753:030crwdne2936753:0 298
crwdns2942667:0crwdne2942667:0 2,048
