Back Cover
crwdns2933313:01crwdne2933313:0 crwdns2934263:00crwdne2934263:0 |
Why is my left joystick grinding? |
Why does it keep disconnecting from the Steam machine? |
crwdns2933313:01crwdne2933313:0 crwdns2934263:02crwdne2934263:0 |
Is there a way to calibrate triggers to finetune their deadzones? |
Up on D-pad not working |
- Spudger
- Tweezers
- iFixit Opening Picks (Set of 6)
- Desoldering Pump
- Microfiber Cleaning Cloths
- FixHub Soldering Toolkit
- No-Clean Flux
- iFixit Desoldering Wick
- Lead-Free Solder
- Heat Gun
- T5 Torx Screwdriver
- Solder Leaded 63/37 Rosin Core
- FixHub Smart Soldering Iron
- TR6 Torx Security Screwdriver
- T4 Torx Screwdriver
- T6 Torx Screwdriver
- Solder ROHS Lead Free Rosin Core
- IA-3952 - Max Professional Consumable Isopropyl Alcohol
Background Information
Announced on November 12, 2025, alongside the Second Generation Steam Machine and the Steam Frame, released on May 4, 2026, the new Steam Controller brings a modern and refined take on Valve’s hallmark game pad. It features two 34.5 mm square trackpads with haptic feedback and pressure-sensitive click strength similar to the Steam Deck. These work alongside two full-size magnetic (TMR) thumbsticks with capacitive touch for reliable, drift-resistant control and intuitive thumb detection.
This controller is designed for Steam Machine, Steam Deck, Steam Frame VR, and more, providing a versatile and deeply configurable controller experience.
Identification
Technical Specifications
Controls & Input
- Gamepad Controls:
- A B X Y Buttons
- D-Pad
- L & R Analog Triggers
- L & R Bumpers
- View & Menu Buttons
- Steam & QAM Buttons
- 4 x Assignable Grip Buttons
- Thumbsticks: 2 x Full-size Magnetic Thumbsticks (TMR) w/ Capacitive Touch
- Haptics: 4 x Haptic Motors
- 2 x LRA Haptic Motors in trackpads for HD Tactile Feedback
- 2 x High Output LRA Haptic Motors in grips for HD Came Haptics including rumble
- Trackpads: 2 x 34.5 mm square trackpads with haptic feedback Pressure-sensitive for configiurable click strength
- Gyro: 6-Axis IMU
- Grip Sense: 2 x Capacitive areas along back of Steam Controller handles
Connectivity
- Steam Controller Puck:
- 2.4 GHz Wireless connection w/ ~8 ms full end-to-end, 4 ms polling rate (measured at 5m)
- Up to 4 Steam Controllers per Steam Controller Puck
- Steam Controller Puck connects to PC via USB-C
- Bluetooth: Bluetooth 4.2 minimum, 5.0 or higher recommended
- USB: USB-C Tethered Play
Power
- Charging:
- Steam Controller Puck charging interface
- USB-Connector
- Battery:
- 8.39 Wh Li-ion battery
- 35+ Hours of Gameplay (reduced hours when playing w/ Steam Frame)
Size & Weight
- Steam Controller:
- Height: 111 mm (4.37 in)
- Width: 159 mm (6.26 in)
- Depth: 57mm (2.24 in)
- Weight: 292 g
- Height: 28 mm
- Width: 50 mm
- Depth: 9 mm
- Weight: 16 g
