crwdns2862668:0crwdne2862668:0
This wiki is missing a device image. Help improve this page by uploading one!
crwdns2935067:01crwdne2935067:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
ALH4240
Background
The Simpson ALH4240 is a gas-powered pressure washer that is part of Simpson's Aluminum Series. This product line features lightweight aluminum frames that are intended for professional use. The pressure washer is equipped with a 389cc Honda GX390 4-stroke OHV commercial grade engine and a CAT triplex plunger pump with a thermal relief valve. The pressure output is 4200 PSI with a flow rate of 4.0 gallons per minute (GPM). The power source for the device is gasoline and it features an aircraft-grade aluminum frame. It has dimensions of 38 x 23.5 x 29 inches and weighs 124 lbs.
The ALH4240 pressure washer can be used for a range of professional cleaning applications including fleet maintenance, construction site cleaning, graffiti removal, and deck restoration. The product has several features such as a 50-ft steel-wire braided high-pressure hose with an ergonomic spray gun and wand, five Quick Connect spray nozzles for various cleaning tasks, an onboard detergent tank with a siphon tube for applying soaps and cleaning chemicals, and pneumatic tires and an integrated handle for maneuverability.
Technical Specifications
  • Engine: 389cc Honda GX390 4-stroke OHV commercial grade engine
  • Pump: Triplex plunger pump with thermal relief valve
  • Pressure: 4200 PSI
  • Flow Rate: 4.0 gallons per minute (GPM)
  • Power Source: Gasoline
  • Frame: Aircraft grade aluminum
  • Dimensions: 38 x 23.5 x 29 inches
  • Weight: 124 lbs
Warranty
The Simpson ALH4240 pressure washer comes with a limited warranty that spans different timeframes for different components of the product. The engine is covered under a 3-year limited commercial warranty, the pump carries a 5-year limited warranty, and the frame is covered for 1 year under a limited warranty. The warranty covers any defects in materials or workmanship from the manufacturer. To claim the warranty, it would typically involve contacting Simpson's customer service or the point of purchase, providing proof of purchase, and details about the issue being experienced. It's important to note that the warranty period begins from the date of purchase.
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2959996:0crwdne2959996:0 286
