crwdns2862668:0crwdne2862668:0
This wiki is missing a device image. Help improve this page by uploading one!
crwdns2935069:02crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
PC1130
Background
The Senco PC1130 is a portable electric air compressor. This device is primarily used for finish work and trim applications, catering to professional contractors and remodelers. Equipped with a 1.5 peak horsepower electric motor, this air compressor has a corded electric power source. It has a tank capacity of 2.5 gallons and can produce a tank pressure of 125 PSI maximum. Furthermore, it provides an air delivery of 2.4 CFM at 100 PSI. The pump up time for this machine is 39 seconds and it operates at a noise level of 68 dB. The dimensions of the Senco PC1130 are 20.5 x 8 x 18.5 inches and it weighs 45.4 lbs.
This air compressor boasts a compact cast iron build, enhancing its durability. It also employs an oil-splash lubrication system, which helps in reducing noise when compared to other oil-lubricated compressors. This device is intended for tasks such as finish carpentry, cabinetry, and trim work. Its low noise output makes it suitable for indoor residential work, making it a reliable choice for operating trim nailers, staplers, and other pneumatic tools. Despite its compact size and low weight, the Senco PC1130 is not intended for high demand continuous use in heavy industrial settings.
Technical Specifications
  • Model Number: PC1130
  • Product Type: Air Compressor
  • Power: 1.5 peak horsepower electric motor
  • Power Source: Corded electric
  • Tank Capacity: 2.5 gallons
  • Tank Pressure: 125 PSI max
  • Air Delivery: 2.4 CFM @ 100 PSI
  • Pump Up Time: 39 seconds
  • Noise Level: 68 dB
  • Dimensions: 20.5 x 8 x 18.5 inches
  • Weight: 45.4 lbs
  • Build: Compact cast iron
  • Lubrication System: Oil-splash
  • Coupler: Universal 1/4 inch
  • Regulator and Pressure Gauge: Included
  • Portability: Weighs under 40 lbs
Warranty
The Senco PC1130 Air Compressor comes with a 2-year limited warranty. This warranty typically covers defects in materials or workmanship under normal use and maintenance. To claim the warranty, it's essential to keep your proof of purchase. If you find your product to be defective within the warranty period, contact the manufacturer, Senco, directly. Make sure to provide them with your model number, a description of the issue, and your proof of purchase. They will provide you with the necessary instructions and may require you to return the product for inspection.
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2942667:0crwdne2942667:0 360
