crwdns2933307:0crwdne2933307:0
Background
The Samsung RF30KMEDB is a 30 cu. ft. French Door refrigerator designed for families and avid entertainers. It features a fingerprint-resistant stainless steel exterior and an external ice and water dispenser. The refrigerator includes a Twin Cooling Plus® system, which maintains optimal humidity levels and prevents odor transfer between compartments. Additional features include LED lighting, Power Freeze and Power Cool options, two humidity-controlled crispers, and gallon door bins for storing large containers.
Technical Specifications
  • Capacity: 30 cu. ft.
  • Type: French Door Refrigerator
  • Finish: Fingerprint Resistant Stainless Steel
  • Dispenser: External Ice and Water Dispenser
  • Lighting: LED
  • Cooling System: Twin Cooling Plus® System
  • Special Features: Power Freeze and Power Cool Options
  • Crispers: Two Humidity-Controlled Crispers
  • Storage: Gallon Door Bins
Troubleshooting
  1. Check that the refrigerator is plugged in properly and the power outlet is working.
  2. Ensure the temperature settings for the refrigerator and freezer compartments are appropriate for your needs. The default settings may need adjustment.
  3. Check for any error codes or flashing lights on the digital display panel which could indicate a sensor issue or other fault. Note the code and contact Samsung support.
  4. Check that the doors are closing and sealing properly. If a door is not sealing fully, it can impact the temperature regulation inside the unit.
  5. Defrost the refrigerator and freezer compartments in case of any ice buildup which can affect performance.
  6. Have a technician check the evaporator fans, electronic control board, thermistors and other components for any faults if issues continue. Repair or replacement of parts may be required.
Samsung RF30KMEDB Owners Manual
eCuration
crwdns2935283:005/19/17crwdne2935283:0
478.744 crwdns2915208:0crwdne2915208:0
crwdns2935297:0396crwdne2935297:0
Staff
crwdns2935297:072.819crwdne2935297:0
crwdns2942667:0crwdne2942667:0 492
