crwdns2935069:04crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
RY253SS
Background
Ryobi String Trimmer RY253SS 2020 is a string trimmer which is used to cut and trim the edges of the lawns to make it look sharp and neat. There are two types of String trimmers available in the market namely gas and electric string trimmers. Gas string trimmers require gas to operate while electric string trimmers require electricity. Electric string trimmers are used by homeowners who use it to maintain small yards. However, Gas string trimmers are used by professionals working in landscaping companies who need to maintain larger yards. You can also use string trimmer as grass trimmer if you want to trim long bushes or obstruction.
Also, there are two techniques string trimmer can be used efficiently they are scything and screeding:
Scything:
  • To scythe in tall grass, choose a gas-powered string trimmer as it will have more power to cut through weeds and grass.
  • Now, start up your trimmer, allowing it time to warm up.
  • Next, take a long stance, holding the trimmer away from your body and begin moving it in a U-shape.
  • Work the trimmer in and out of the cutting area in the U-shape until grass or weeds are at your desired level.
Screeding:
  • Once again, start up your trimmer, allowing it time to warm up.
  • Then, tip the string trimmer so that the string is sitting just off the pavement and move it onto the weed's base.  Be sure you are flush with the hard surface.
  • Be extra cautious when using this technique: If you have too shallow of an angle, you will not have an effective cut. On the other hand, if you hold too high, you will create an angle too sharp and not cut evenly.
 The above information is taken from a project guide posted on How to use a string trimmer. The Home Depot. (n.d.). Retrieved February 7, 2023, from TheHomeDepot website.
String trimmers from Ryobi are known to be very reliable and efficient. The Ryobi string trimmer RY253SS was launched in the year 2020 and is equipped with 25 CC of engine. You can also use different attachments available in the market with which you can use the string trimmer for different uses.
Identification
The specifications are given for string trimmer with straight shaft the string trimmer with curved shaft have curved shaft attachment in the front which can easily be identified by looking at the shape of the trimmer. Also, Ryobi RY253SS_2020 comes standard in one colour which is green and black.
Assembled Depth (in.)
11 in
Assembled Height (in.)
60 in
Assembled Width (in.)
10 in
Line Style Size
.095
Maximum Cutting Path Diameter (in.)
18
Recommended Line Diameter (in.)
.095
Shaft Length (in.)
53
The above specifications were taken from TheHomeDepot product page.
Technical Specification
Shaft Length (in.)
53
Assembly Required
Yes
Engine Cycles
2 Cycle
Engine Displacement (cc)
25
Engine Type
2-Cycle
Features
Attachment Capable
Fuel Tank Capacity (oz.)
12 oz
Line Advance System
Bump
Number of Trim Lines
2
Power Type
Gas
Product Weight (lb.)
12.2
Shaft Type
Straight
Start Type
Manual
Tools Included
String Trimmer
Trimmer Line Type
String
Trimmer Type
Walk Behind
source for the above information is TheHomeDepot product page details.
Additional Information
Ryobi String trimmer Operators manual.
Repair Sheet.
How to maintain your String Trimmer.
Best String trimmer for your lawn.
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:07crwdne2936753:0 33
crwdns2936753:030crwdne2936753:0 127
crwdns2959996:0crwdne2959996:0 4,582
