crwdns2935069:010crwdne2935069:0
Background and Identification
The Rug Doctor Extractor Wide Track Carpet Cleaner is a carpet cleaning machine that was released in 2016. It is an extraction cleaner, which means that it uses a vibrating brush to agitate dirt and dust in the carpet, and a vacuum to extract the dirty water and dry the carpet. Drying the carpet quickly after washing it is important to prevent water damage to the carpet.
Rug Doctor makes both standard and Wide Track models for rent or purchase. According to their website, the Wide Track model has a 30% larger tank and a 16% wider cleaning path than a standard model, which means that the user can cover a larger strip of carpet more efficiently than they could with a standard model. They also have to stop less often to empty the recovery tank once it is full. This carpet cleaner is industrial-grade, and users should read the manual carefully to ensure that they use it correctly.
Technical Specifications
  • Assembled Depth: 24 in
  • Assembled Height: 27.5 in (handle folded for storage)
  • Assembled Width: 13 in
  • Weight: 40 lbs
  • Brush Width: 11.25 in
  • Vacuum Width: 12.4 in
  • Speed: 2,500 RPM brush motor
  • Motor: Two-stage bypass 108" water lift vac motor
  • Amperage: 12 A
  • Cleaning Tank Capacity (gallons): 3.7
  • Recovery Tank Capacity: 4.8 gallons
  • PSI: 35
  • GPM: 0.85
Additional Information
Water Extraction Cleaning - Wikipedia
Instruction Guide
Home Depot Rental Page
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 64
crwdns2936753:030crwdne2936753:0 282
crwdns2959996:0crwdne2959996:0 14,567
