crwdns2935069:04crwdne2935069:0
Background and Identification
The Rhino multi-pro XA model 301003 is a gasoline-powered post driver that is manufactured as a part of Rhino’s pro-series line of gasoline post drivers. The multi-pro XA can be adapted to drive a range of post diameters and materials without having to change the driver’s anvil. Depending on the type of post-installation, a chuck change may be required.
The post driver comes standard with Rhino’s extended anvil and longer 2.5-inch ID master chuck. The multi-pro XA model features double-sided, sealed bearings on all rotating parts and a removable bottom handle. Users can purchase Rhino’s Chuck-Lok 1-inch, 1-3/4-inch, and 2-inch adapters. A tension-grip crankcase cover provides tool-free removal for ease of lubricant application. The driver can quickly be removed from the post with a two-piece adapter design. The multi-pro XA pole driver is also equipped with Rhino’s CIS vibration damping for user comfort.
The Rhino multi-pro XA model 301003 is powered by a Honda GX35 four-stroke engine. There is no mixing of gas and oil within this engine, making it easier to maintain. The GX35 is a 35.88cc (1.3 horsepower) four-stroke engine that replaced the GX31 engine as Honda’s most powerful handheld engine. The engine can hold 3.4 ounces of oil and 0.67 quarts or 0.1675 gallons of fuel. Honda recommends using unleaded 86 octane or higher gasoline for this engine.
Technical Specifications
  • Item: Post Driver
  • 2-Cycle/4-Cycle: 4-Cycle
  • Engine Brand: Honda X35
  • Engine Displacement: 35.8 cc
  • Blows per Minute: 1,725
  • Drives Rod and Stake Diameter: 1/2 in. to 7/8 in.
  • Drives Round Post Diameter:1 in. to 2-3/8 in.
  • Drives T-Posts: Yes
  • Driveshaft Connection: Centrifugal Clutch
  • Series: Multi-Pro
  • Vibration Dampening: Yes
  • Maximum dBA:100
  • Handle Type: Cushion Grip
  • Throttle Control: Finger Type, Single Handle
  • Fuel Tank Capacity: 0.65 L
  • Post Driver Weight: 51 lb
  • Post Driver Width: 10 3/4 in
  • Post Driver Depth: 17 in
  • Post Driver Height: 26 in
  • Includes: (3) Chuck-Lock(TM) Adapters System
Additional Information
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 79
crwdns2959996:0crwdne2959996:0 3,379
