crwdns2933307:0crwdne2933307:0
The Raspberry Pi Zero is a computer the size of a stick of gum, which is designed to be as cheap as possible, with a starting price of $5 (or $10 for a version with Wi-Fi). With dimensions of just 2.6 x 1.2 x 0.2 inches (66.0mm x 30.5mm x 5.0mm), about the size of a USB Flash drive, the Pi Zero is small enough to be embedded in a project and cheap enough to be left there! The same Raspberry Pi OS and software runs on the Raspberry Pi Zero as on larger Pis such as the Raspberry Pi 4, though the smaller board cannot handle the new, 64-bit version of the OS. It may only be a single core machine, but the Pi Zero packs enough power to get the job done.
Specs
CPU 1-GHZ, Broadcom BCM2835
RAM 512MB
Wireless (Pi Zero W only) 802.11n / Bluetooth 4.1 / LE
Ports Micro USB, mini HDMI
I/O 40 GPIO Pins, CSI camera connector (not on version 1.2)
Size 2.6 x 1.2 x 0.2 inches (66.0mm x 30.5mm x 5.0mm)
Weight 0.31 ounces (9 grams)
Versions
  • Raspberry Pi Zero W: Clearly the best choice, but with an MSRP of $10, slightly more expensive than the regular Pi Zero, this version includes Wi-Fi and Bluetooth connectivity.
  • Raspberry Pi Zero (version 1.3): The current version of the Zero lacks wireless connectivity, but has an MSRP of just $5, which makes it attractive for a project where you either don’t need network access or can have it USB connected to a PC.
  • Raspberry Pi Zero (version 1.2): The original version of the Pi Zero lacked the CSI camera connector that version 1.3 and Pi Zero W have. This model has been replaced so you’re unlikely to see it for sale anywhere.
Just Some Stuff
crwdns2935283:012/07/20crwdne2935283:0
96 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 80
crwdns2959996:0crwdne2959996:0 2,125
