crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0crwdns2935091:0crwdnd2935091:0crwdne2935091:0
Background and Identification
The ROG Strix GeForce® GTX 1070 Ti Advanced edition is a desktop graphics card released by Asus in November 2017. It is part of the Republic of Gamers (ROG) series, which is aimed at high-end gaming enthusiasts. The card is based on the Nvidia GeForce GTX 1070 Ti GPU, which is a slightly faster version of the GTX 1070. The ROG Strix GeForce® GTX 1070 Ti Advanced edition has a factory overclocked core clock speed of 1683 MHz in gaming mode and 1759 MHz in OC mode, and a memory clock speed of 8008 MHz. It also features Aura Sync RGB lighting, which allows users to customize the color and effects of the LED lights on the card.
The card has a triple-fan cooling system with patented wing-blade fans that provide high airflow and low noise. It also has MaxContact technology, which is a copper heat spreader that makes direct contact with the GPU for improved heat transfer. The card requires a 500W power supply and an 8-pin power connector. It has four video outputs: one DVI-D port, two HDMI 2.0 ports, and two DisplayPort 1.4 ports. It supports up to four displays and VR devices.
Technical Specifications
Clock speeds
- Base: 1607 MHz
- Boost: 1759 MHz
- Memory: 8008 MHz
Memory
- 8 GB
- GDDR5
Connections
- 2 x HDMI 2.0
- 2 x DisplayPort
- 1 x DVI-D
- 1 x PCIe x16 (Interface)
- 1x PCIe x8 (External Power)
Power
- 150 Watts
- 3 Cooling fans
