crwdns2933313:01crwdne2933313:0 crwdns2934263:00crwdne2934263:0 |
Why is my usb hub very heat and not work only heat |
crwdns2933313:01crwdne2933313:0 crwdns2934263:01crwdne2934263:0 |
Plugable usb-c 7 in 1 hub doesn't working Plugable usb-c 7 in 1 hub do |
Background Information
Plugable's USB-C 7-in-1 Multiport Hub is a USB-C accessory designed to expand the connectivity options of devices that have a USB-C or Thunderbolt 3/4 port. The hub adds 3 USB 3.0 ports, a 4K HDMI port, 1 Standard SD Card slot, 1 MicroSD Card slot, and a USB-C port for charging.
Technical Specifications
Compatible Systems
- Chromebook
- Windows
- Mac
- Linux
- iPadOS (2018+ iPad Mirroring Only)
Video Output
- Port: 1 x HDMI 4K (Output)
- Placement: Rear
- HDMI Specification: 1.4
- Resolution & Refresh Rates:
- 3440x1440 @ 60Hz
- 2560x1440 @ 60Hz
- 2560x1080 @ 60Hz
- 1920x1200 @ 60Hz
- 1920x1080 @ 60Hz
- 1600x900 @ 60Hz
- 1280x1024 @ 60Hz
- 1280x800 @ 60Hz
- 1280x720 @ 60Hz
- 1152x864 @ 60Hz
- 1024x768 @ 60Hz
- 800x600 @ 60Hz
- 640x480 @ 60Hz
- 3840x2160 @ 30Hz
- HDCP: Display Dependent
- Chipset: PS176 Parade
Power
USB-C Power Passthrough
- Placement: Left
- Power Host/Device: Device
- Voltage: Up to 20 V
- Amperage: 5.0 A
- Wattage: Up to 100 W
USB-C to Host
- Placement: Front
- Power Host/Device: Host
- Amperage: 4.6 A
- Wattage: Up to 92 W
USB to Device
- Ports: 3 x USB-A
- Placement: Left
- USB Version and Link Rate: USB 3.0 (5 Gbps)
- Voltage: 5 V
- Amperage: 900 mA
- Wattage: 4.5 W
Connection to Host
- Ports: 1 x USB-C
- Placement: Front
- Features: Alternate Mode Video
Storage
Slot One
- Host Connection: USB-C
- Slot and Media Type:
- MicroSD
- MicroSD (Trans-Flash)
- MicroSDHC
- MicroSDXC
- Chipset: GL3224 Genesys Logic
Slot Two
- SD
- SDHC
- SDXC
- MMC
- RSMMC
- Mobile-MMC
- MMCPlus
- MMC-micro
- Chipset: GL3224 Genesys LogicBackground Information
Physical Specifications
- Dimensions:
- Height: 0.5 in (1.26 cm)
- Width: 1.6 in (4.1 cm)
- Depth: 4.1 in (10.4 cm)
- Weight: 2.5 oz (71 grams)
- SKU/Part Number: USBC-7IN1
In the Box
- 1 x Plugable USB-C 7-in-1 hub
- 1 x Quick Start Guide
