crwdns2933315:06crwdne2933315:0
crwdns2934263:01crwdne2934263:0
The Panasonic NB-G110P Toaster Oven has a common failure mode where the main on/off switch becomes increasingly intermittent.
1) If it’s not too bad yet try simply cleaning the switch: unplug the toaster oven, pry off the grey plastic on-off button to expose the head of the on/off switch and apply some electrical contact cleaner (CorrosionX or MG Chemicals Super Contact Cleaner or something similar) or, less ideally, 91% or better isopropyl alcohol. Work the switch a bit by turning it on and off a lot (still unplugged) and see if that doesn't fix the problem.
2) If the switch does need to be replaced (SW 15 on the circuit board) a fairly common 7x7mm 6-pin DPDT (dual-pole-dual-throw) switch will work as an acceptable substitute.
For a more complete write-up see https://fixitclinic.blogspot.com/2016/12...
For additional background see https://uspirg.org/blogs/blog/usp/troubl...
Fixit Clinic
crwdns2935283:001/13/15crwdne2935283:0
786 crwdns2915208:0crwdne2915208:0
Global Fixers crwdns2935289:0Global Fixerscrwdne2935289:0
Community
crwdns2931471:068crwdne2931471:0
crwdns2935297:03.039crwdne2935297:0
crwdns2936753:030crwdne2936753:0 53
crwdns2942667:0crwdne2942667:0 2,375
