crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0crwdns2935091:0crwdnd2935091:0crwdne2935091:0
Always the right detergent for every application - CapDosing portioned dispensing
Select from various special detergents and fabric conditioners, such as ImpraProtect, CottonRepair or Booster for stubborn stains. Our capsule cups are made from 100 % recycled plastic. They are dispensed precisely and release the detergent as soon as they come into contact with water. This prevents too little or too much detergent being dispensed. If necessary, the Caps can be opened using the opening tag.
Lead by example - Additional energy efficiency
Miele washing machines have been specifically designed to cut down on water and energy consumption. This means that some models save as much as 10% more than the highest energy efficiency class, A. So you benefit from outstanding wash results that are kind to your wallet and the environment.
Laundry care - Tested for the equivalent of 20 years’ use
While some car engines are subjected to 3000 hours of tests, we test continuous performance for up to 10,000 hours. Day and night. Comprehensive and precise. So we can guarantee you outstanding results for years and years.
Safety thanks to an additional sensor - Water Control System (WCS)
The Water Control System (WCS) monitors the water intake with a water level sensor. Water intake is stopped automatically if the normal water level is not reached. If there is water leakage inside the machine, the inlet valve inside the machine closes and water in the suds container is pumped away. A float switch in the drip tray also detects leaking water.
Guaranteed water protection! - Water protection guarantee
Miele provides protection for your home for all Miele water protection systems - for 20 years. Should you incur damage to property as a result of a defect in the water protection system, you have a safety guarantee. In the context of the terms and conditions of the water protection system Miele will bear the costs for property damage resulting from any defect of the system. so long as the appliance was professionally installed.
Economical, powerful and maintenance-free - ProfiEco motor
The ProfiEco motor from Miele is a particularly powerful inverter drive, engineered to deliver its performance as economical and quiet as possible. The motor is electronically controlled, which means it doesn’t use carbon brushes and isn’t subject to the usual wear. An innovative design that ensures many years of efficient, carefree, and convenient laundry care.
Tailored to your load - Automatic load recognition
All Miele washing machines feature automatic load recognition, an intelligent feature that carefully analyses your current laundry in the drum and uses precisely the right amount of water and electricity needed. Equally impressive, it does all this while still achieving the excellent cleaning results you’ve come to expect from us.
Optimum care of synthetic fibres - Delicates
Gentle & soft: with the special programme synthetic textiles stay beautiful & keep their shape.
Most gentle treatment of your favourite garments - Woollens
No shrinkage, no felting: Delicate wool fabrics are cared for particularly gently, maintaining their quality.
Equip textiles with functions - Proofing
Best possible effect: Thermally fixing ensures optimum water-repellent properties.
Special programme for high-tech materials - Outerwear
Best care without the loss of function: High-quality outdoor textiles retain their functionality in any weather.
Add or remove single items - AddLoad
AddLoad has you covered. This feature allows you to simply add that runaway shirt, or that pesky sock that always seems to escape your grasp, or remove single items like that new black shirt in your white wash. Anytime during a washing cycle. Your selected programme will automatically continue.
Keep your clothing safe while tumbling - Honeycomb drum
The unique design of our honeycomb drum cares just as much for the wellbeing and preservation of your clothes as you, with its specially engineered shape creating a layer of water between drum and laundry when rotating. This allows fabrics to safely glide along, protects fibres, and ensures your clothes last longer.
Key Features:
- Suitable for stacking
- Side-by-side
- Slot-in
- Can be built-under
- Rinse hold
- Without spin function
- AutoClean detergent drawer
- Low temperature wash "Cold" and "20 °C"
- Automatic load control
- Flow meter
- Foam sensing
- ProfiEco motor
- Short
- Soak
- Water plus
- Additional rinse cycle
- Safety lock
- PIN-Code
- Optical interface
- Tested for the equivalent of 20 years’ use.
- Save even more energy with A -10%
- Perfect supplement for specific applications –CapDosing
- Gentle laundry care thanks to theMiele honeycomb drum
- Add or remove individual items during the wash cycle with AddLoad
