crwdns2911028:0crwdne2911028:0
crwdns2862668:0crwdne2862668:0
This wiki is missing a device image. Help improve this page by uploading one!
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
Background and Identification
The Micro H2 Meter model 044-11 was released in 1998 and is a handheld device used to monitor and diagnose the amount of lactose malabsorption in the bloodstream, bacterial overgrowth, and measurements of intestinal transit time in adults and children’s.
The Micro H2 Meter is equipped with a user-friendly display reading of Hydrogen unit levels in parts per million(ppm) and supplied with different configuration mouthpiece adapters, mask adapters, and disposable cardboard mouth adapters. The Micro H2 Meter is power by a 9V single Alkaline battery and is equipped with connections for Hydrogen sensor calibrations.
Note: It is important to service and calibrate the Micro H2 Meter to sustain the accurate measurement of the device and the sustainable life of the device.
The Micro H2 device has a built-in feature to alarm users for sensor drift and will require calibration. Only remove the battery if the device is not being used for 3-months or needs replacing. If the battery has been removed, a recalibration is required. The manufacture recommends a 2-year H2 sensor replacement and for any other serving needed to contact an authorized distributor or support@micromedical.com.uk.
To use, simply exhale slowly into the Micro H2 Meter mouthpiece and measurement will display. For young children who cannot meet the requirements, an optional gas sampling system is available.
Device Specifications
Type: Micro fuel cell
Range: 0-500 ppm
Resolution: 1ppm
Accuracy: +/-5% of full scale or 1ppm (depends on which value is greater)
Sensor Life: > 18 months
Response time: <70 sec (to 90% of reading)
Operating temperature: 0 -40 C
Operating humidity: 30-90% continues (0-99% intermittent)
Operatoring pressure: Atmosphere +/- 10.
Pressure coefficient: .02% single per mBar
Baseline drift: 0 ppm (auto zero)
Long term drift: <2% signal loss per month
Power source: 9V single Alkaline battery
Battery life: >30 hours of continuous used
Weight: 160g
Dimensions: 170X 60 X26 mm
Display: 3/1/2 digit LCD
Storage temperature: -20C to +70C
Storage humidity: 30%-90%
Additional Information
Micro H2 Brochure
2016 Micro H2 Meter Operating Manual
More Information and Where You Can Purchase
Micro CO Manual With Useful Troubleshooting Information
Justin Ogihara
crwdns2935283:009/18/17crwdne2935283:0
31,641 crwdns2915208:0crwdne2915208:0
crwdns2935297:052crwdne2935297:0
crwdns2959996:0crwdne2959996:0 439
