crwdns2911028:0crwdne2911028:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
Background
The Medical Microlab Spirometer is the Model 3300 Version 043-12 that was released in 1998.
This device page is necessary for making repairs on a spirometer, which is used for measuring respiratory flow rates in patients, especially those with chronic obstructive pulmonary disease (otherwise known as COPD). Because this is a piece of medical equipment, it is critical that this device properly works without faults, and if it were to have complications, it is important to know how to fix it. The information provided is directed towards biomedical technicians and pulmonologists who oversee the maintenance of medical tools and equipment.
This specific device is battery-powered, and the batteries can be recharged. It can be customized to perform different types of tests. For example: when performing a relaxed vital capacity test, the operator of the machine must have a patient breathe into this device, and the results will display on the screen in the form of a flow/volume curve. More detailed information regarding the different types of tests that can be performed with this device can be found in the operating manual.
This is not the most recent model of this device, with newer models operating more commonly than this one. However, it is not extinct yet, and this page can provide any owner of the 1998 Medical Microlab Model 3300 Version 043-12 with the resources to resolve any issues with the device.
Identification
The content provided is specifically for the 1998 Model 3300 version 043-12.
To identify the model, it has a LCD graphic display, data entry keypad, and RS232 serial interface.
Observe the following precautions when using this device:
  • Avoid exposing the MicroLab to direct sunlight.
  • Avoid operating the spirometer in dusty conditions or near to heating appliances or radiators.
  • Do not keep the spirometer in a damp place or expose it to extremes of temperature.
  • Do not direct the transducer holder towards a strong light source whilst operating the spirometer.
  • Check the AC charger for compatibility with local power rating.
Technical Specifications
Not all spirometer models are built equally. Before using this guide, ensure that this model matches the model you have to reduce the risk of further damage or other issues.
Release Date: 1998
Model Number: 3300
Version Number: 043-12
Display: Graphic LCD 128x64 dots
Printer Type: 320 dot per line thermal printer
Storage: 90 tests
Transducer: Micro Medical Bi-Directional Digital Volume
Resolution: 10ml Volume 0.03l/s Flow
Power Supply: Input 100 to 250V, 50 to 60Hz. Output 12V 1.5A (Class 1 equipment)
Battery Pack: Rechargeable NiCad 7.2V 600mA hours
Dimensions: 134x274x51.5mm. Transducer 50x60x90mm
Weight: 820g, 2.3kg with carry case and accessories
Operating Temperature: 0 to +40 C
Operating Humidity: 30% to 90% RH
Storage Temperature: -20 to + 70 C
Storage Humidity: 10% to 90% RH
Known Failures:
  • When the unit is turned on there is no display present
  • When the unit is turned on the display is dark purple
  • FVC readings are low
  • The unit does not record any blows
Note: This device can be affected by cell phones and electromagnetic interference exceeding certain levels.
Additional Information
MicroLab 3300 Operating Manual
Required Battery: Rechargeable NiCad 7.2V 600mAh
Microlab - Service Manual
Justin Ogihara
crwdns2935283:009/18/17crwdne2935283:0
31,641 crwdns2915208:0crwdne2915208:0
crwdns2935297:052crwdne2935297:0
crwdns2959996:0crwdne2959996:0 555
