crwdns2935069:03crwdne2935069:0
CA-3504-HDHB
Background
The Mi-T-M model CA-3504-HDHB is a 3500 PSI gasoline-powered pressure washer that is designed for heavy-duty projects such as mildew removal, sanitation, large areas, and industrial jobs. The CA-3504-HDHB model pressure washer operates at a rate of 3.5 gallons per minute and includes 15- and 25-degree nozzles, as well as a detergent nozzle. It includes a 50-foot by 3/8-inch hose with a trigger gun and a 36-inch lance.
The CA-3504-HDHB model pressure washer includes the Mi-T-M Pressure Relief State that eliminates pressure build-up in the system. It also includes a thermal relief valve and an in-line water strainer.
The CA-3504-HDHB model pressure washer includes a Honda four-stroke GX390UT2 engine. The GX390UT2 engine is a 389 cubic centimeter overhead valve (OHV) engine. It produces 11.7-horsepower at 3,600 revolutions per minute. Its fuel tank can hold up to 6.4 quarts of gasoline and it includes a separate oil tank with a capacity of 1.16 quarts. Honda recommends using unleaded 86 octane or higher fuel for this engine.
Identification
The CA-3504-HDHB model pressure washer includes an aluminum frame and a base plate with 1-1/4-inch tube handles and a vibration isolation plate with four rubber isolators. The pressure washer includes 13-inch plastic tires. The Honda four-stroke GX390UT2 engine can be identified by its red engine cover, a white fuel tank, and a mechanical box with a black cover. The name “Honda” is printed in white font on the side of the engine cover along with the model “GX” in red font and “390” in black font with a white border.
Technical Specifications
Details:
  • Weight (lbs.): 125 lbs
  • PSI: 3500
  • GPM: 3.5
  • Displacement/ Engine: 389cc Honda GX390 OHV
  • Pump: AR
  • Mi-T-M No.: 3-0310
  • Unloader: Mi-T-M, Adjustable Pressure
  • Lance: 48 in.
Dimensions:
  • Assembled Depth (in.): 40 in
  • Assembled Height (in.): 27 in
  • Assembled Width (in.): 23 in
Additional Information
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 36
crwdns2959996:0crwdne2959996:0 1,591
