crwdns2935067:01crwdne2935067:0
crwdns2933307:0crwdne2933307:0 crwdns2934263:00crwdne2934263:0 |
blade is not locking |
HM1214CX
Background and Identification
Makita is a Japanese power tool manufacturer that was founded in 1915. It is a leading brand of professional-grade tools. This company produces cordless tools, power tools, petrol equipment, and batteries for the cordless tools. The tools themselves range from wrenches and drills to chainsaws and lawnmowers. This 27 lb demolition hammer can be used to break through concrete, and should be handled carefully. The user should carefully follow all safety guidelines given by the manufacturer.
The Makita Rotary Hammer HM1214CX (an alternate model number is HM1214CQ) uses AVT, also known as Anti-Vibration Technology, to reduce shaking and improve the efficiency of the hammer. It does this with a counterbalancing weight located inside the hammer. As the hammer impacts the surface, the counterbalance weight moves around to provide an opposing force to the push of the ground on the hammer. This reduces the vibrations produced by the hammer significantly, making it easier and safer to operate. This design is based on seismic or earthquake engineering principles.
Technical Specifications
- Blows Per Minute (variable speed) : 950 - 1,900 BPM
- Impact Energy (ft.lbs.) : 19
- Impact Energy (Joules) : 25.7 J
- AMPS : 14
- Noise Level : 101 dB
- Vibration (m/s²) : 8
- Overall Length : 27-1/2"
- Net Weight : 27.1 lbs.
- Bit Type : Accepts SDS-MAX
- Breaker/Demo class : 27
- Power Type : Corded
