crwdns2935067:01crwdne2935067:0
crwdns2933307:0crwdne2933307:0 crwdns2934263:00crwdne2934263:0 |
has sat for a year,won't start. |
DPC7311HD
Background and Identification:
The Makita DPC7311HD is a gasoline-powered cutter. It is powered by a two-stroke 5.6-horsepower engine. It is overall a lightweight power machine weighing 22.04 lb. The saw has a 14 inch blade with a max cutting depth of 4-13/16 inches. The saw is intended to be used outdoors only for trimming and cutting metal beams, cast iron pipes, stone blocks, and asphalt. This saw is also known by the name DPC7310HD. The saw was first produced in 2015 and sold for $1,499.40.
The Makita DPC7311HD also has a self-tensioning belt designed to provide a more consistent power transfer. It includes an on-off choke operation switch with a touch-stop function for operator safety. Makita recommends using a 50:1 ratio of fuel to oil mix for two-stroke cycle engines. Makita high-performance two-stroke engine oil (50:1) is available in 100 mL and 1 liter.
The product can be identified by the identification plate at the bottom backside of the device, which will include the model number, serial number, and manufacturing date.
Technical Specifications:
Product dimensions:
o Product Length: 30-3/4"
o Product Height: 17.875"
o Product Width: 12.25"
o Wheel Diameter: 14"
o Overall Length: 30-3/4"
o Weight: 22.04 lbs.
o Max. Cutting Depth: 4-13/16"
Products specifications:
o Engine: 5.6 HP/4 kW
o Power Type: 2-stroke gas
o Max speed: 9,340 RPM
o Idle speed :2.500 RPM
o Fuel Type: unleaded regular gasoline with a min. octane value of 91
o Fuel Tank Capacity: 37 oz.
Arbor w/ Adaptor: 20mm/1" adaptor
Additional Information:
· MANUAL: Contains the safe protocols regarding how to use the device.
· PARTS LIST AND LOCATION: Will help in finding parts needed to fix the device
· PARTS BREAK DOWN: A map that helps in locating the various parts throughout the device
· TOOL FLYER: The original flyer that the tool was sold with including its price.
